주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
In this guide, you will be removing the battery housing from the back housing. The GoPro Hero5 Black is waterproofed with plenty of adhesives. By completing this guide, you will have to remove the adhesive and your GoPro will no longer be waterproof.
  1. While pressing the button on the bottom of the GoPro, slide the battery door to the side to pop it open. While pressing the button on the bottom of the GoPro, slide the battery door to the side to pop it open. While pressing the button on the bottom of the GoPro, slide the battery door to the side to pop it open.
    • While pressing the button on the bottom of the GoPro, slide the battery door to the side to pop it open.
  2. Grab the plastic flap on the battery and pull the battery out. Grab the plastic flap on the battery and pull the battery out. Grab the plastic flap on the battery and pull the battery out.
    • Grab the plastic flap on the battery and pull the battery out.
  3. Pull and twist the lens cover right or left until it pops off. The lens cover is secured tightly and might be difficult to twist off.
    • Pull and twist the lens cover right or left until it pops off.
    • The lens cover is secured tightly and might be difficult to twist off.
    レンズを回すには爪などをレンズカバーと本体との隙間に入れて、手前に引き出してから回転させます。
    Taizo Yamamoto - 답글
  4. This step is not necessary but will make the process of removing the faceplate much easier.
    • This step is not necessary but will make the process of removing the faceplate much easier.
    • Refer to the iOpener instructions for how to heat up and use the iOpener.
    • Apply the heated iOpener to the front of the GoPro for a few minutes to melt the adhesive under the faceplate.
    • The heated iOpener is very hot and can burn your hands. Avoid burns by using towels or gloves to hold the iOpener.
  5. Starting with the edges, use the spudger to pry off the faceplate. The faceplate is held down with adhesive and may take a while to get off. The faceplate is held down with adhesive and may take a while to get off.
    • Starting with the edges, use the spudger to pry off the faceplate.
    • The faceplate is held down with adhesive and may take a while to get off.
  6. Remove the six T3 Torx screws. Remove the six T3 Torx screws.
    • Remove the six T3 Torx screws.
    Where can I get the screw driver
    subashzeeq - 답글
    Mine are actually T4 screws.
    John Hahn - 답글
  7. Be careful when pulling open the motherboard assembly as it is still connected to the back housing by four cables. The cables may break if stretched. Using the spudger, slowly pry open the motherboard assembly from the LCD side of the GoPro. Using the spudger, slowly pry open the motherboard assembly from the LCD side of the GoPro.
    • Be careful when pulling open the motherboard assembly as it is still connected to the back housing by four cables. The cables may break if stretched.
    • Using the spudger, slowly pry open the motherboard assembly from the LCD side of the GoPro.
    Little FYI ; pry slightly on the side with the LCD. Once it pops, work the other slightly. Then pull the board up and out but remember the cables. THE PICTURE ABOVE WHERE THE METAL SHIELD IS IS THE CAMERA LENS! CABLES ARE ON THE SIDE WHERE YOU BEGIN PRYING.
    stevan othon - 답글
  8. Use the flat end of a spudger to pry the three ribbon cables connected to the side of the motherboard. Use the flat end of a spudger to pry the three ribbon cables connected to the side of the motherboard. Use the flat end of a spudger to pry the three ribbon cables connected to the side of the motherboard.
    • Use the flat end of a spudger to pry the three ribbon cables connected to the side of the motherboard.
  9. Use the flat end of the spudger to pry the battery housing power cable straight up from its socket on the motherboard. Use the flat end of the spudger to pry the battery housing power cable straight up from its socket on the motherboard.
    • Use the flat end of the spudger to pry the battery housing power cable straight up from its socket on the motherboard.
  10. Remove the  3mm #000 Phillips screw.
    • Remove the 3mm #000 Phillips screw.
    • Remove the 2mm #000 Phillips screw.
  11. Use the tweezers to grasp the housing firmly and pull it away from the three ribbon cables.
    • Use the tweezers to grasp the housing firmly and pull it away from the three ribbon cables.
    • Pull the battery housing until the half circle grooves on the back housing match up with the grooves on the battery housing.
    • After the screws have been removed from the inside, the battery housing is only held down by adhesive.
  12. Make sure the half circle grooves match up. Otherwise the battery housing will not be able to be pulled out. With your fingers, push from the inside of the battery compartment and pull the battery housing out from the back housing.
    • Make sure the half circle grooves match up. Otherwise the battery housing will not be able to be pulled out.
    • With your fingers, push from the inside of the battery compartment and pull the battery housing out from the back housing.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Christopher Adams
회원 가입일: 2016년 10월 03일
1,782 평판
안내서 5개 작성하였습니다
Cal Poly, Team 18-6, Forte Fall 2016 Cal Poly, Team 18-6, Forte Fall 2016 회원
CPSU-FORTE-F16S18G6
4 회원들
안내서 13개 작성하였습니다
Is there any glue to use to make the case waterproof again?
Dominik Lisiakiewicz - 답글
댓글 쓰기
조회 통계:
24 시간 전: 7
7일 전: 28
30일 전: 80
전체 시간: 8,888
