소개
In this guide, you will be separating the motherboard from the Midframe of the GoPro Hero5 Black. The GoPro Hero5 Black is waterproofed with plenty of adhesives. By completing this guide, you will have to remove the adhesive and your GoPro will no longer be waterproof.
필요한 것
While pressing the button on the bottom of the GoPro, slide the battery door to the side to pop it open.
Pull and twist the lens cover right or left until it pops off.
レンズを回すには爪などをレンズカバーと本体との隙間に入れて、手前に引き出してから回転させます。
Refer to the iOpener instructions for how to heat up and use the iOpener.
Apply the heated iOpener to the front of the GoPro for a few minutes to melt the adhesive under the faceplate.
Using the spudger, slowly pry open the motherboard assembly from the LCD side of the GoPro.
Little FYI ; pry slightly on the side with the LCD. Once it pops, work the other slightly. Then pull the board up and out but remember the cables. THE PICTURE ABOVE WHERE THE METAL SHIELD IS IS THE CAMERA LENS! CABLES ARE ON THE SIDE WHERE YOU BEGIN PRYING.
Use the flat end of the spudger to pry the battery housing power cable straight up from its socket on the motherboard.
Use the flat end of the spudger to pry the black cover plate straight up from its socket on the motherboard.
다른 20명이 해당 안내서를 완성하였습니다.
댓글 11개
Hi
I took off only faceplate. Do you guys have an idea how to make it waterproof again? What can be used as an adhesive? Thanks
you can try silicone glue, although obviously there is no guarantee to what extent it would be waterproof.
I used this guide to replace the USB port in my GP5. Does anyone know of a good way to hold the face plate down once it’s been removed? Not looking to make it waterproof again, just trying to hold the faceplate down a little better.
Mario Wong - 답글
I would try either a silicone- or cyanoacrylate- (super glue) based adhesive. You can try to peel off the blue gasket and/or sand where the two pieces meet for better adhesion.
Be careful with CA glue. The vapors as it dries can haze over some plastics. I’m going to try silicone-based.
Hello, Do somebody know what size the six screws showed on step 6?
