소개
Replacing an arm on the Karma can be done in less than 20 minutes. There are four main steps: removing the landing gear, removing the old arm, installing the new arm, reattaching the landing gear. This video will walk you through each step.
필요한 것
동영상 지침
거의 끝나갑니다!
결론
다른 3명이 해당 안내서를 완성하였습니다.
댓글 3개
Juste merci !
cedricgaeta - 답글
Can someone tell me what tools are needed? I’m looking first to see if I can repait a slightly cracked arm before needing to replace?
lenodski - 답글
The only tool needed is a 2.5mm hex key.
Blake Klein -
