주요 콘텐츠로 건너뛰기
GoPro Karma Arms Replacement
필요한 것
  1. GoPro Karma Arms Replacement, Battery: 1 단계, 이미지 1/1
    • Hook your fingers on the tab and pull out the battery.
  2. GoPro Karma Arms Replacement, Stabilizer: 2 단계, 이미지 1/3 GoPro Karma Arms Replacement, Stabilizer: 2 단계, 이미지 2/3 GoPro Karma Arms Replacement, Stabilizer: 2 단계, 이미지 3/3
    • Locate stabilizer collar’s unlock and lock symbols. Twist the collar counterclockwise to unlock the stabilizer from GoPro Karma body.
    • Place the GoPro Karma on a stable surface with the legs folded in and the stabilizer facing towards yourself.
  3. GoPro Karma Arms Replacement: 3 단계, 이미지 1/1
    • Remove the stabilizer by pulling the entire stabilizer out of the drone body.
  4. GoPro Karma Arms Replacement, Landing Gear: 4 단계, 이미지 1/1
    • Flip the drone upside down with the landing gear out.
    • Remove the four 1.2 cm long hex screws with a Hex 2.0 screwdriver in the four corners of the landing gear
  5. GoPro Karma Arms Replacement: 5 단계, 이미지 1/1
    • Push with your thumb and pull up with your fingers to remove the landing gear.
    • Caution: The landing gear is connected by a thin cable so do not pull too far away.
  6. GoPro Karma Arms Replacement: 6 단계, 이미지 1/2 GoPro Karma Arms Replacement: 6 단계, 이미지 2/2
    • Flip over the landing gear and locate the cable connector.
    • Use your thumbnail to disconnect the cable and free the landing gear.
  7. GoPro Karma Arms Replacement, Arms: 7 단계, 이미지 1/1
    • Remove the two 1.2 cm long hex screws with a Hex 2.0 screwdriver and set them aside.
  8. GoPro Karma Arms Replacement: 8 단계, 이미지 1/2 GoPro Karma Arms Replacement: 8 단계, 이미지 2/2
    • Remove both locked connectors by pushing the connector release tool into the hole in the center and pulling up with the white handles.
    • The connector release tool is only included with the purchase of a replacement arm from the GoPro website.
    • If you do not have a connector release tool, use a small screwdriver to push each tab while pulling up with the white handles.
  9. GoPro Karma Arms Replacement: 9 단계, 이미지 1/3 GoPro Karma Arms Replacement: 9 단계, 이미지 2/3 GoPro Karma Arms Replacement: 9 단계, 이미지 3/3
    • Remove the cover plate by pulling up on the side.
    • Feed each connector through the hole and set aside the cover plate.
  10. GoPro Karma Arms Replacement: 10 단계, 이미지 1/2 GoPro Karma Arms Replacement: 10 단계, 이미지 2/2
    • Loosen the 2 cm long hex screw in the arm with a Hex 2.0 screwdriver.
    • The screw will not come out but loosen it until it can rotate easily.
    • Pull up and off the broken arm.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Kyle Hoff
회원 가입일: 04/23/18
141 평판
안내서 1개 작성함
Cal Poly, Team S25-G14, Maness Spring 2018 Cal Poly, Team S25-G14, Maness Spring 2018 회원
CPSU-MANESS-S18S25G14
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 11
30일 전: 25
전체 시간: 2,152
