주요 콘텐츠로 건너뛰기
GoPro Karma Harness Replacement
필요한 것
  1. GoPro Karma Harness Replacement, Stabilizer: 1 단계, 이미지 1/3 GoPro Karma Harness Replacement, Stabilizer: 1 단계, 이미지 2/3 GoPro Karma Harness Replacement, Stabilizer: 1 단계, 이미지 3/3
    • Locate stabilizer collar’s unlock and lock symbols. Twist the collar counterclockwise to unlock the stabilizer from GoPro Karma body.
    • Place the GoPro Karma on a stable surface with the legs folded in and the stabilizer facing towards yourself.
  2. GoPro Karma Harness Replacement: 2 단계, 이미지 1/1
    • Remove the stabilizer by pulling the entire stabilizer out of the drone body.
  3. GoPro Karma Harness Replacement, Harness: 3 단계, 이미지 1/3 GoPro Karma Harness Replacement, Harness: 3 단계, 이미지 2/3 GoPro Karma Harness Replacement, Harness: 3 단계, 이미지 3/3
    • Place finger on the tab to open the harness and remove the camera.
    • Be sure to pull the camera straight out lest you damage the connectors.
  4. GoPro Karma Harness Replacement: 4 단계, 이미지 1/1
    • Using a Hex 2.0mm screwdriver, remove the two 12 mm hex screws closest to the harness.
  5. GoPro Karma Harness Replacement: 5 단계, 이미지 1/3 GoPro Karma Harness Replacement: 5 단계, 이미지 2/3 GoPro Karma Harness Replacement: 5 단계, 이미지 3/3
    • Pull the harness off of the stabilizer.
    • Be sure to pull the harness straight off lest you damage the connector.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Max Verspieren
회원 가입일: 04/19/18
97 평판
안내서 1개 작성함
Cal Poly, Team S25-G14, Maness Spring 2018 Cal Poly, Team S25-G14, Maness Spring 2018 회원
CPSU-MANESS-S18S25G14
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 10
30일 전: 18
전체 시간: 1,193
