주요 콘텐츠로 건너뛰기
GoPro Karma Landing Gear Replacement
필요한 것
  1. GoPro Karma Landing Gear Replacement, Battery: 1 단계, 이미지 1/1
    • Hook your fingers on the tab and pull out the battery.
  2. GoPro Karma Landing Gear Replacement, Stabilizer: 2 단계, 이미지 1/3 GoPro Karma Landing Gear Replacement, Stabilizer: 2 단계, 이미지 2/3 GoPro Karma Landing Gear Replacement, Stabilizer: 2 단계, 이미지 3/3
    • Locate stabilizer collar’s unlock and lock symbols. Twist the collar counterclockwise to unlock the stabilizer from GoPro Karma body.
    • Place the GoPro Karma on a stable surface with the legs folded in and the stabilizer facing towards yourself.
  3. GoPro Karma Landing Gear Replacement: 3 단계, 이미지 1/1
    • Remove the stabilizer by pulling the entire stabilizer out of the drone body.
  4. GoPro Karma Landing Gear Replacement, Landing Gear: 4 단계, 이미지 1/1
    • Flip the drone upside down with the landing gear out.
    • Remove the four 1.2 cm long hex screws with a Hex 2.0 screwdriver in the four corners of the landing gear
  5. GoPro Karma Landing Gear Replacement: 5 단계, 이미지 1/1
    • Push with your thumb and pull up with your fingers to remove the landing gear.
    • Caution: The landing gear is connected by a thin cable so do not pull too far away.
  6. GoPro Karma Landing Gear Replacement: 6 단계, 이미지 1/2 GoPro Karma Landing Gear Replacement: 6 단계, 이미지 2/2
    • Flip over the landing gear and locate the cable connector.
    • Use your thumbnail to disconnect the cable and free the landing gear.
결론
Jay Ingram
회원 가입일: 04/19/18
334 평판
안내서 3개 작성하였습니다
Cal Poly, Team S25-G14, Maness Spring 2018 Cal Poly, Team S25-G14, Maness Spring 2018 회원
CPSU-MANESS-S18S25G14
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 8
전체 시간: 591
