주요 콘텐츠로 건너뛰기
Golf Club Grip Replacement
필요한 것
  1. Golf Club Grip Replacement, Grip: 1 단계, 이미지 1/2 Golf Club Grip Replacement, Grip: 1 단계, 이미지 2/2
    • Place the golf club securely on a level table.
    • Using a blade or knife, cut a line through the grip.
  2. Golf Club Grip Replacement: 2 단계, 이미지 1/3 Golf Club Grip Replacement: 2 단계, 이미지 2/3 Golf Club Grip Replacement: 2 단계, 이미지 3/3
    • Remove the grip from the golf club shaft.
  3. Golf Club Grip Replacement: 3 단계, 이미지 1/1
    • Use the knife to take off any excess residue from the shaft of the club.
  4. Golf Club Grip Replacement: 4 단계, 이미지 1/2 Golf Club Grip Replacement: 4 단계, 이미지 2/2
    • Apply the double sided tape to the bare shaft in a spiral pattern.
    • Use the grip to determine how far up the shaft the tape needs to go.
  5. Golf Club Grip Replacement: 5 단계, 이미지 1/1
    • Remove the tape backing.
  6. Golf Club Grip Replacement: 6 단계, 이미지 1/3 Golf Club Grip Replacement: 6 단계, 이미지 2/3 Golf Club Grip Replacement: 6 단계, 이미지 3/3
    • Place a golf tee in the hole at the end of the golf grip.
  7. Golf Club Grip Replacement: 7 단계, 이미지 1/2 Golf Club Grip Replacement: 7 단계, 이미지 2/2
    • Pour a generous amount of adhesive into the opposite end of the grip.
    • Squeeze together the open end of the grip.
    • Lightly shake, in order to spread the adhesive within the grip.
  8. Golf Club Grip Replacement: 8 단계, 이미지 1/1
    • Over a bowl or container, pour adhesive in the grip onto the shaft of the golf club.
  9. Golf Club Grip Replacement: 9 단계, 이미지 1/2 Golf Club Grip Replacement: 9 단계, 이미지 2/2
    • Remove the tee from the back of the grip.
    • Push the grip onto the golf club shaft.
    • Ensure that the end of the grip is hitting the end of the shaft.
  10. Golf Club Grip Replacement: 10 단계, 이미지 1/1
    • Allow to dry at least 12 hours before use.
결론
After allowing the club to properly dry, you will have a new grip to improve your swing at tee off.
다른 6명이 해당 안내서를 완성하였습니다.
Skylar Nichols
회원 가입일: 09/30/16
212 평판
안내서 1개 작성함
Missouri Western, Team 1-8, Adkins Fall 2016 Missouri Western, Team 1-8, Adkins Fall 2016 회원
MWSU-ADKINS-F16S1G8
3 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 29
30일 전: 58
전체 시간: 6,677
