주요 콘텐츠로 건너뛰기
Golf Club Shaft Replacement
필요한 것
  1. Golf Club Shaft Replacement, Shaft: 1 단계, 이미지 1/1
    • Use a heat gun to melt the old epoxy holding the club head to the old shaft.
    • Caution: Heat guns can get very hot, so use caution when handling them.
  2. Golf Club Shaft Replacement: 2 단계, 이미지 1/3 Golf Club Shaft Replacement: 2 단계, 이미지 2/3 Golf Club Shaft Replacement: 2 단계, 이미지 3/3
    • Stabilize the club shaft using a vise grip or the weight of a friend.
    • With a pair of oven mitts, remove the club head by carefully twisting it from the shaft.
  3. Golf Club Shaft Replacement: 3 단계, 이미지 1/2 Golf Club Shaft Replacement: 3 단계, 이미지 2/2
    • Clean out the inside of the club head with acetone and a small wire brush.
    • Cleaning the club head will make applying the new epoxy effective.
  4. Golf Club Shaft Replacement: 4 단계, 이미지 1/1
    • Place the cleaned club head on the new shaft and mark the where the end of the club head reaches on the shaft.
    • Remove the club head.
  5. Golf Club Shaft Replacement: 5 단계, 이미지 1/3 Golf Club Shaft Replacement: 5 단계, 이미지 2/3 Golf Club Shaft Replacement: 5 단계, 이미지 3/3
    • Take some sand paper and sand the shaft past your mark leading to the tip.
    • A good technique is to wrap the sandpaper around the tip while twisting the hand holding the sandpaper back and forth.
  6. Golf Club Shaft Replacement: 6 단계, 이미지 1/3 Golf Club Shaft Replacement: 6 단계, 이미지 2/3 Golf Club Shaft Replacement: 6 단계, 이미지 3/3
    • Get the epoxy ready by pouring it into a plate.
    • Use a toothpick to apply epoxy into the part of the club head that goes over the shaft.
  7. Golf Club Shaft Replacement: 7 단계, 이미지 1/3 Golf Club Shaft Replacement: 7 단계, 이미지 2/3 Golf Club Shaft Replacement: 7 단계, 이미지 3/3
    • Slide the new shaft into the club head.
    • Wipe off the excess epoxy that squeezes out.
    • Let the epoxy set overnight for an optimal seal, then it will be ready for use.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
George Bassili
회원 가입일: 04/30/21
166 평판
안내서 1개 작성함
CSU Los Angeles, Team S1-G35, Harris Spring 2021 CSU Los Angeles, Team S1-G35, Harris Spring 2021 회원
CSULA-HARRIS-S21S1G35
1 회원
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 18
30일 전: 74
전체 시간: 1,213
