주요 콘텐츠로 건너뛰기
Goodman GSX16 Central Air Conditioning Unit Filter Replacement
  1. Goodman GSX16 Central Air Conditioning Unit Filter Replacement, Filter: 1 단계, 이미지 1/1
    • Turn the air conditioner unit off prior to changing the air filter.
  2. Goodman GSX16 Central Air Conditioning Unit Filter Replacement: 2 단계, 이미지 1/1
    • Go into the attic where your air conditioner unit is located via the access door on the ceiling or wherever your air conditioner is located.
  3. Goodman GSX16 Central Air Conditioning Unit Filter Replacement: 3 단계, 이미지 1/3 Goodman GSX16 Central Air Conditioning Unit Filter Replacement: 3 단계, 이미지 2/3 Goodman GSX16 Central Air Conditioning Unit Filter Replacement: 3 단계, 이미지 3/3
    • Open the filter access door and pull the old filter out.
  4. Goodman GSX16 Central Air Conditioning Unit Filter Replacement: 4 단계, 이미지 1/1
    • Place the new filter in the unit with the arrow pointing towards the air conditioner unit.
  5. Goodman GSX16 Central Air Conditioning Unit Filter Replacement: 5 단계, 이미지 1/1
    • Close the door to the filter and make sure it is snug with no air leakage.
  6. Goodman GSX16 Central Air Conditioning Unit Filter Replacement: 6 단계, 이미지 1/1
    • Turn the air conditioner unit back on.
결론
Janice Farris
회원 가입일: 10/08/20
141 평판
안내서 1개 작성함
University of Memphis, Team S3-G21, Willis Fall 2020 University of Memphis, Team S3-G21, Willis Fall 2020 회원
UM-WILLIS-F20S3G21
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 22
30일 전: 97
전체 시간: 2,079
