소개
Keep your Goodman Split Air Conditioning unit in good working order with a fast and easy filter replacement. A clean air filter is important for maintaining optimal home air quality, removing dust particles, and reducing home energy costs.
Goodman recommends replacing the filter every 90 days. This guide will show you how to perform this necessary maintenance routine.
The replacement requires a Goodman-compatible filter. No tools are required. The estimated time involved is 5 minutes.
필요한 것
Follow local guidelines for proper disposal of the old filter.
Replace filter every three months or as needed.
다른 한 분이 해당 안내서를 완성하였습니다.
