주요 콘텐츠로 건너뛰기
Google Home Interconnect Cable Replacement
필요한 것
  1. Google Home Interconnect Cable Replacement, Interconnect Cable: 1 단계, 이미지 1/3 Google Home Interconnect Cable Replacement, Interconnect Cable: 1 단계, 이미지 2/3 Google Home Interconnect Cable Replacement, Interconnect Cable: 1 단계, 이미지 3/3
    • Removing the lid too quickly could cause you to tear the interconnect cable that attaches the base to the top of the lid.
    • Pull off the Google Home’s magnetically attached base and set it aside.
    • Using a Torx T6 screwdriver head, unscrew the four 1.7mm Torx screws deep in the speaker recess so that you can remove the lid.
    • After all four screws are out, pop the lid off the device to open the capsule.
  2. Google Home Interconnect Cable Replacement: 2 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Carefully remove the interconnect cable using a pair of tweezers.
결론
Gabe Hyun
회원 가입일: 04/17/18
826 평판
안내서 4개 작성하였습니다
Cal Poly, Team S24-G11, Maness Spring 2018 Cal Poly, Team S24-G11, Maness Spring 2018 회원
CPSU-MANESS-S18S24G11
4 회원들
안내서 5개 작성하였습니다
댓글 한 개
What cord can you replace with? There is an adaptor attached.
Katti Sundelin - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 16
전체 시간: 690
