소개
A guide to disassemble Google Home Mini for further repairs.
필요한 것
Remove the rubber bottom as per the Google Home Mini teardown guide.
Remove the four 7mm T6 Torx screws from the bottom.
Using a pair of tweezers, unlatch the Zero Insertion Force (ZIF) fastener that connects the ribbon cable to the board.
What if this breaks off. Can i direct connect power.
Where to buy it please tell please
Babu Vlogs - 답글
다른 12명이 해당 안내서를 완성하였습니다.
댓글 2개
How did you get the rubber base off of it?
There’s a little more explanation here
