주요 콘텐츠로 건너뛰기
Google Home Mini Speaker Replacement
필요한 것
  1. Google Home Mini Speaker Replacement, Google Home Mini Disassembly: 1 단계, 이미지 1/1
    • Place device on a flat surface.
  2. Google Home Mini Speaker Replacement: 2 단계, 이미지 1/1
  3. Google Home Mini Speaker Replacement: 3 단계, 이미지 1/1
    • Remove the lower half of the device.
    • Be careful as a black ribbon cable connects the two halves together.
  4. Google Home Mini Speaker Replacement: 4 단계, 이미지 1/1
    • Using a pair of tweezers, unlatch the Zero Insertion Force (ZIF) fastener that connects the ribbon cable to the board.
    • Flip up and push the ZIF fastener towards outside of the lower case to loosen it.
  5. Google Home Mini Speaker Replacement: 5 단계, 이미지 1/1
    • Pull the ribbon cable off.
  6. Google Home Mini Speaker Replacement, Speaker: 6 단계, 이미지 1/1
    • Remove the four 7.8mm T8 Torx screws.
  7. Google Home Mini Speaker Replacement: 7 단계, 이미지 1/3 Google Home Mini Speaker Replacement: 7 단계, 이미지 2/3 Google Home Mini Speaker Replacement: 7 단계, 이미지 3/3
    • The speaker will still be connected to the device.
    • Using your fingers, disconnect the wires.
결론
다른 8명이 해당 안내서를 완성하였습니다.
Mia Sulaiman
회원 가입일: 05/21/18
1,032 평판
안내서 3개 작성하였습니다
IUPUI, Team S1-G4, Harley Spring 2018 IUPUI, Team S1-G4, Harley Spring 2018 회원
IUPUI-HARLEY-S18S1G4
7 회원들
안내서 5개 작성하였습니다
댓글 2개
HI There I only have 2 lights on the google mini - and although it was working yesterday - with all 4 lights - it most certainly isn't now? I am not sure why and I am not sure what has happened?
susan woods - 답글
Okay, but where can one obtain a spare speaker?
Bil McArthur - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 21
30일 전: 78
전체 시간: 7,008
