주요 콘텐츠로 건너뛰기
Google Home Mini USB Power Port Replacement
필요한 것
  1. Google Home Mini USB Power Port Replacement, Google Home Mini Disassembly: 1 단계, 이미지 1/1
    • Place device on a flat surface.
  2. Google Home Mini USB Power Port Replacement: 2 단계, 이미지 1/1
  3. Google Home Mini USB Power Port Replacement: 3 단계, 이미지 1/1
    • Remove the lower half of the device.
    • Be careful as a black ribbon cable connects the two halves together.
  4. Google Home Mini USB Power Port Replacement: 4 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Using a pair of tweezers, unlatch the Zero Insertion Force (ZIF) fastener that connects the ribbon cable to the board.
    • Flip up and push the ZIF fastener towards outside of the lower case to loosen it.
  5. Google Home Mini USB Power Port Replacement: 5 단계, 이미지 1/1
    • Pull the ribbon cable off.
  6. Google Home Mini USB Power Port Replacement, USB Power Port: 6 단계, 이미지 1/2 Google Home Mini USB Power Port Replacement, USB Power Port: 6 단계, 이미지 2/2
    • Remove the three 5.3mm T6 Torx screws from the board.
  7. Google Home Mini USB Power Port Replacement: 7 단계, 이미지 1/2 Google Home Mini USB Power Port Replacement: 7 단계, 이미지 2/2
    • Remove the black metal plate from the board.
  8. Google Home Mini USB Power Port Replacement: 8 단계, 이미지 1/2 Google Home Mini USB Power Port Replacement: 8 단계, 이미지 2/2
    • Remove the board.
결론
다른 9명이 해당 안내서를 완성하였습니다.
Mia Sulaiman
회원 가입일: 05/21/18
1,056 평판
안내서 3개 작성하였습니다
IUPUI, Team S1-G4, Harley Spring 2018 IUPUI, Team S1-G4, Harley Spring 2018 회원
IUPUI-HARLEY-S18S1G4
7 회원들
안내서 5개 작성하였습니다
댓글 8개
Where I can buy micro USB PCB ?
so_ang - 답글
Planet Carl - 답글
Would like to know this as well disapointing to have an instruction on how to replace a part, but nowere to buy it.
Wolve 8383 - 답글
Has anyone had any luck buying a replacement part?
Caitlin Barnum - 답글
Just broke mine :-(
Is anyone managed to find a place to buy one?
Jim - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 21
30일 전: 62
전체 시간: 6,311
