주요 콘텐츠로 건너뛰기
Google Home Motherboard Replacement
필요한 것
  1. Google Home Motherboard Replacement, Interconnect Cable: 1 단계, 이미지 1/3 Google Home Motherboard Replacement, Interconnect Cable: 1 단계, 이미지 2/3 Google Home Motherboard Replacement, Interconnect Cable: 1 단계, 이미지 3/3
    • Removing the lid too quickly could cause you to tear the interconnect cable that attaches the base to the top of the lid.
    • Pull off the Google Home’s magnetically attached base and set it aside.
    • Using a Torx T6 screwdriver head, unscrew the four 1.7mm Torx screws deep in the speaker recess so that you can remove the lid.
    • After all four screws are out, pop the lid off the device to open the capsule.
  2. Google Home Motherboard Replacement: 2 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Carefully remove the interconnect cable using a pair of tweezers.
  3. Google Home Motherboard Replacement, Mute Button Switch: 3 단계, 이미지 1/2 Google Home Motherboard Replacement, Mute Button Switch: 3 단계, 이미지 2/2
    • Remove the ‘O-ring’ that wraps around the device holding the switch panel in place.
  4. Google Home Motherboard Replacement: 4 단계, 이미지 1/2 Google Home Motherboard Replacement: 4 단계, 이미지 2/2
    • Using a Torx T6 screwdriver head, unscrew the four black 1.7mm Torx screws.
    • Remove the panel and the mute button switch. If done correctly you should now be able to see the device’s guitar-shaped motherboard.
  5. Google Home Motherboard Replacement, Motherboard: 5 단계, 이미지 1/2 Google Home Motherboard Replacement, Motherboard: 5 단계, 이미지 2/2
    • Disconnect the foam-padded, red and black cable that connects the motherboard to the sound driver, by squeezing and pulling on the tab
    • Disconnect the orange interconnect cable that connects the bottom of the device to the motherboard by pulling straight out on the orange tab.
  6. Google Home Motherboard Replacement: 6 단계, 이미지 1/2 Google Home Motherboard Replacement: 6 단계, 이미지 2/2
    • Using a Torx T6 screwdriver head, unscrew the five silver 1.7mm Torx screws keeping the motherboard in place.
    • Remove the motherboard.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Maya Wharton
회원 가입일: 04/17/18
175 평판
안내서 1개 작성함
Cal Poly, Team S24-G11, Maness Spring 2018 Cal Poly, Team S24-G11, Maness Spring 2018 회원
CPSU-MANESS-S18S24G11
4 회원들
안내서 5개 작성하였습니다
댓글 2개
Where can one purchase a replacement motherboard?
Jim Pflasterer - 답글
Most likely the only place to do so would be through contacting Google, as there is no parts sold at retail, only full units
Nick Bergstrom -
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 14
30일 전: 30
전체 시간: 3,172
