주요 콘텐츠로 건너뛰기
Google Pixel 2 Display Adhesive Replacement
필요한 것
  1. Google Pixel 2 Display Adhesive Replacement, Display Adhesive: 1 단계, 이미지 1/1
    • Remove any trace of the old adhesive from the Pixel 2's case.
    • If you're reinstalling your existing display, be sure to remove any remaining adhesive from the back of your display as well.
    • Take special care to remove any small glass fragments.
    • After removing all traces of glue and glass, clean the adhesion areas with high concentration isopropyl alcohol (at least 90%). This will ensure a better seal for the display.
    • If your new display doesn't come with speaker grilles or a front-facing camera bracket, make sure to install those before applying display adhesive.
    The grey liner on the inside of the case is dissolved by rubbing alcohol. Don't get any on it.
    user39581 - 답글
  2. Google Pixel 2 Display Adhesive Replacement: 2 단계, 이미지 1/1
    • Peel the clear backing off of the replacement adhesive.
  3. Google Pixel 2 Display Adhesive Replacement: 3 단계, 이미지 1/1
    • There are perforations along the inner and outer edges of the adhesive strip.
    • Carefully tear along the perforations to separate the outer portion of the adhesive backing from the adhesive strip.
    • Be very careful not to tear the adhesive, the white backing, or the blue backing underneath the adhesive. Only remove the blue plastic surrounding the outside edge of the adhesive strip.
  4. Google Pixel 2 Display Adhesive Replacement: 4 단계, 이미지 1/2 Google Pixel 2 Display Adhesive Replacement: 4 단계, 이미지 2/2
    • Peel away the white backing, exposing one side of the adhesive strip.
    • Carefully place the adhesive strip on the phone case, with the exposed side down, and the blue backing up.
    • Start at the bottom of the case, lining up the contours along the bottom edge of the adhesive with those of the case. Then lay down the rest of the adhesive.
  5. Google Pixel 2 Display Adhesive Replacement: 5 단계, 이미지 1/2 Google Pixel 2 Display Adhesive Replacement: 5 단계, 이미지 2/2
    • With the adhesive lined up with the edges of the case, use your finger or a spudger to press the adhesive strip down against the case.
    • Use a pair of tweezers to remove the inner portion of the blue backing. It may be necessary to hold the adhesive down with a spudger to avoid pulling up the adhesive strip.
    • Be very careful and avoid tearing or removing the adhesive.
  6. Google Pixel 2 Display Adhesive Replacement: 6 단계, 이미지 1/1
    • Use tweezers to peel away the blue backing over top of the adhesive without peeling the adhesive off of the case.
    • If the adhesive starts to come off of the case as you remove the backing, you may need to slide a spudger in between the adhesive and the backing to hold the adhesive down.
    Getting this in place was really a pain. In a few places, it flipped 180deg on my but I don’t think it matters since the screen will compress the adhesive strip when you finally press it back.
    John Reagan - 답글
결론
다른 17명이 해당 안내서를 완성하였습니다.
Adam O'Camb
회원 가입일: 04/11/15
196,113 평판
안내서 416개 작성하였습니다
댓글 한 개
Adhesive tend to stick inside the bag, use extra caution to remove sheet from the package.
Do not touch adhesive at any point, you might mess up the forming of the adhesive.
U Hang Chiang - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 9
30일 전: 53
전체 시간: 7,309
