주요 콘텐츠로 건너뛰기
이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
Google Pixel 2 Opening Procedure
단지 전제 조건
이 안내서는 다른 가이드의 선행 작업으로 사용하기 위한 것입니다. 그 자체로는 불완전합니다.
필요한 것
  1. Google Pixel 2 Opening Procedure, Opening Procedure: 1 단계, 이미지 1/2 Google Pixel 2 Opening Procedure, Opening Procedure: 1 단계, 이미지 2/2
    • If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping the glass. This also makes a smooth surface allowing the suction cup to bond.
    • Apply a suction cup as close to the volume button edge of the phone as you can while avoiding the curved edge.
    • The suction cup will not make a good seal on the curved portion of the glass.
  2. Google Pixel 2 Opening Procedure: 2 단계, 이미지 1/3 Google Pixel 2 Opening Procedure: 2 단계, 이미지 2/3 Google Pixel 2 Opening Procedure: 2 단계, 이미지 3/3
    • Pull up on the suction cup with firm, constant pressure and insert an opening pick between the front panel and rear case.
    • Do not insert the pick deeper than 1.5 mm, or you risk damaging the OLED panel.
    • This requires a significant amount of force and patience. If you have trouble, rock the suction cup and screen to weaken the adhesive, or apply heat with an iOpener, heat gun, or hair dryer.
    • The display panel is fragile. If you plan to re-use your display, take care to insert your tool only as far as necessary to separate the adhesive. Inserting the tool any further can damage the OLED panel under the glass.
  3. Google Pixel 2 Opening Procedure: 3 단계, 이미지 1/2 Google Pixel 2 Opening Procedure: 3 단계, 이미지 2/2
    • In the following steps, extra caution is required in certain areas to avoid damage to the phone:
    • Do not insert the pick more than 9 mm into the bottom edge of the phone. If the pick contacts the folded portion of the OLED panel it can damage the display.
    • Only make very shallow cuts in the upper left corner, prying deeply can damage the front-facing camera.
    • Inserting an opening tool deeper than 1.5 mm into the sides of the device, or 9 mm into the top and bottom can permanently damage the display.
  4. Google Pixel 2 Opening Procedure: 4 단계, 이미지 1/2 Google Pixel 2 Opening Procedure: 4 단계, 이미지 2/2
    • In the following steps, use the flat of the opening pick, rather than a corner, to cut here. This will help prevent inserting the pick too deeply.
    • Slide the opening pick up the right side of the phone to separate the display adhesive.
    • Take extra care with the side bezels, which are only 1.5 mm deep.
  5. Google Pixel 2 Opening Procedure: 5 단계, 이미지 1/3 Google Pixel 2 Opening Procedure: 5 단계, 이미지 2/3 Google Pixel 2 Opening Procedure: 5 단계, 이미지 3/3
    • Slide the opening pick around the upper-right corner and along the top edge of the phone.
  6. Google Pixel 2 Opening Procedure: 6 단계, 이미지 1/3 Google Pixel 2 Opening Procedure: 6 단계, 이미지 2/3 Google Pixel 2 Opening Procedure: 6 단계, 이미지 3/3
    • Slide the pick around the upper-left corner of the phone and down the left edge of the phone.
  7. Google Pixel 2 Opening Procedure: 7 단계, 이미지 1/3 Google Pixel 2 Opening Procedure: 7 단계, 이미지 2/3 Google Pixel 2 Opening Procedure: 7 단계, 이미지 3/3
    • Slide the pick around the bottom-left corner and along the bottom of the phone. Keep pick at a slight angle away from the screen to avoid damage to the OLED corners.
    • Take extra care not to insert the opening pick more than 9 mm to avoid damaging the OLED panel.
  8. Google Pixel 2 Opening Procedure: 8 단계, 이미지 1/2 Google Pixel 2 Opening Procedure: 8 단계, 이미지 2/2
    • Reinsert the pick at the top edge of the phone and gently pry up the display.
    • If the display doesn't readily lift, do some extra prying to separate the last of the adhesive. The adhesive near the upper speaker is thicker than other places.
    • Don't try to fully separate the display yet, as a fragile ribbon cable still connects it to the phone's motherboard.
  9. Google Pixel 2 Opening Procedure: 9 단계, 이미지 1/2 Google Pixel 2 Opening Procedure: 9 단계, 이미지 2/2
    • Carefully lay the display down on top of the rear case as shown, making sure not to crease or tear the display ribbon cable.
    • Remove the two 4.0 mm T5 Torx screws securing the display cable bracket.
  10. Google Pixel 2 Opening Procedure: 10 단계, 이미지 1/1
    • Remove the display cable bracket.
  11. Google Pixel 2 Opening Procedure: 11 단계, 이미지 1/2 Google Pixel 2 Opening Procedure: 11 단계, 이미지 2/2
    • Use the point of a spudger to lift the display cable connector up and out of its socket on the motherboard.
    • Avoid touching the motherboard with the tip of your spudger. The components surrounding the socket are fragile.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
    • If any part of your screen doesn't respond to touch after your repair re-seat this connector, making sure it clicks fully into place and that there's no dust or other obstruction in the socket.
    • During reassembly, pause here and replace the adhesive around the edges of the display.
결론
Adam O'Camb
회원 가입일: 04/11/15
196,299 평판
안내서 416개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 308
