주요 콘텐츠로 건너뛰기
Google Pixel 2 XL Charging Assembly Replacement
보관된 가이드
해당 안내서는 단지 역사적인 목적으로 보관됩니다. 최신 버전 안내서를 사용하여 수리 하십시오.
필요한 것
  1. Google Pixel 2 XL Charging Assembly Replacement, SIM Card: 1 단계, 이미지 1/2 Google Pixel 2 XL Charging Assembly Replacement, SIM Card: 1 단계, 이미지 2/2
    • Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray, located on the left edge of the phone, opposite of the power and volume buttons.
    • Press firmly to eject the tray.
  2. Google Pixel 2 XL Charging Assembly Replacement: 2 단계, 이미지 1/1
    • Remove the SIM card tray from the phone.
    • The SIM card will fall out of the tray easily.
    • When reinserting the SIM card, ensure that it is in the proper orientation relative to the tray.
  3. 주의: 3-14 단계들은 진행 중으로 표시된 안내서에서 제공되었습니다.
    Google Pixel 2 XL Charging Assembly Replacement, Opening Procedure: 3 단계, 이미지 1/2 Google Pixel 2 XL Charging Assembly Replacement, Opening Procedure: 3 단계, 이미지 2/2
    • If your display glass is cracked, tape over the glass to prevent bodily harm and further breakage. This also makes a smooth surface allowing the suction cup to bond.
    • Apply a suction cup as close to the SIM slot edge of the phone as you can while avoiding the curved edge.
    • The suction cup will not make a good seal on the curved portion of the glass.
  4. Google Pixel 2 XL Charging Assembly Replacement: 4 단계, 이미지 1/3 Google Pixel 2 XL Charging Assembly Replacement: 4 단계, 이미지 2/3 Google Pixel 2 XL Charging Assembly Replacement: 4 단계, 이미지 3/3
    • Pull up on the suction cup with firm, constant pressure and insert an opening pick between the front panel and rear case.
    • This requires a significant amount of force and patience. If you have trouble, rock the suction cup and screen to weaken the adhesive, or apply heat with an iOpener, heat gun, or hair dryer.
  5. Google Pixel 2 XL Charging Assembly Replacement: 5 단계, 이미지 1/2 Google Pixel 2 XL Charging Assembly Replacement: 5 단계, 이미지 2/2
    • In the following steps, extra caution is required in certain areas to avoid damage to the phone:
    • Do not insert the pick more than 0.25 inches (6 mm) into the bottom edge of the phone. If the pick contacts the folded portion of the OLED panel, it can damage the display.
    • Do not cut along the left edge; there are delicate display cables that can be damaged.
    • Only make very shallow cuts in the upper left corner; prying deeply can damage the front-facing camera.
  6. Google Pixel 2 XL Charging Assembly Replacement: 6 단계, 이미지 1/2 Google Pixel 2 XL Charging Assembly Replacement: 6 단계, 이미지 2/2
    • Slide the opening pick down the right side of the phone to separate the display adhesive.
  7. Google Pixel 2 XL Charging Assembly Replacement: 7 단계, 이미지 1/3 Google Pixel 2 XL Charging Assembly Replacement: 7 단계, 이미지 2/3 Google Pixel 2 XL Charging Assembly Replacement: 7 단계, 이미지 3/3
    • In the following steps, use the flat edge of the opening pick, rather than a corner, to cut. This will help prevent inserting the pick too deeply.
    • Slide the opening pick around the lower-right corner and along the bottom edge of the phone.
  8. Google Pixel 2 XL Charging Assembly Replacement: 8 단계, 이미지 1/3 Google Pixel 2 XL Charging Assembly Replacement: 8 단계, 이미지 2/3 Google Pixel 2 XL Charging Assembly Replacement: 8 단계, 이미지 3/3
    • Reinsert the flat edge of the pick at the top-right corner of the phone, and slide it around the corner and the top edge of the phone.
  9. Google Pixel 2 XL Charging Assembly Replacement: 9 단계, 이미지 1/2 Google Pixel 2 XL Charging Assembly Replacement: 9 단계, 이미지 2/2
    • Gently lift the display from the right side of the phone, opening it like a book.
    • If the display doesn't readily lift, do some extra prying to separate the last of the adhesive.
    • Don't try to fully separate the display yet, as fragile ribbon cables still connect it to the phone's motherboard.
    • Carefully lay the display flat on the table next to the rest of the phone, keeping it close to the phone to avoid straining the display and digitizer cables.
  10. Google Pixel 2 XL Charging Assembly Replacement: 10 단계, 이미지 1/2 Google Pixel 2 XL Charging Assembly Replacement: 10 단계, 이미지 2/2
    • Use the corner of an opening tool to pry up and unclip on the lower edge of the digitizer cable connector cover.
    • The clip securing this cover is along the bottom edge.
    • Pry carefully to avoid damaging the cable underneath, or losing the cover itself.
    • Remove the connector cover.
    • Make sure to keep this component so you can reinstall it during reassembly.
  11. Google Pixel 2 XL Charging Assembly Replacement: 11 단계, 이미지 1/2 Google Pixel 2 XL Charging Assembly Replacement: 11 단계, 이미지 2/2
    • Use the point of a spudger to lift the digitizer cable connector up and out of its socket on the motherboard.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
    • If any part of your screen doesn't respond to touch after your repair, re-seat this connector, making sure it clicks fully into place and that there's no dust or other obstruction in the socket.
  12. Google Pixel 2 XL Charging Assembly Replacement: 12 단계, 이미지 1/1
    • Use tweezers to remove any tape from the display connector cover.
  13. Google Pixel 2 XL Charging Assembly Replacement: 13 단계, 이미지 1/2 Google Pixel 2 XL Charging Assembly Replacement: 13 단계, 이미지 2/2
    • Insert the point of a spudger into the small hole on the edge of the display connector cover.
    • Use the spudger to pry the cover out of its recess.
  14. Google Pixel 2 XL Charging Assembly Replacement: 14 단계, 이미지 1/2 Google Pixel 2 XL Charging Assembly Replacement: 14 단계, 이미지 2/2
  15. Google Pixel 2 XL Charging Assembly Replacement, Midframe: 15 단계, 이미지 1/1
    이 단계에 사용된 도구:
    Magnetic Project Mat
    $19.95
    구매
    • Remove eleven 3.8 mm Phillips screws securing the midframe.
  16. Google Pixel 2 XL Charging Assembly Replacement: 16 단계, 이미지 1/3 Google Pixel 2 XL Charging Assembly Replacement: 16 단계, 이미지 2/3 Google Pixel 2 XL Charging Assembly Replacement: 16 단계, 이미지 3/3
    • Insert an opening tool into the notch in the midframe near the volume buttons and pry the midframe up and away from the rest of the phone.
    • Remove the midframe.
  17. Google Pixel 2 XL Charging Assembly Replacement, Battery Connector: 17 단계, 이미지 1/2 Google Pixel 2 XL Charging Assembly Replacement, Battery Connector: 17 단계, 이미지 2/2
    • Use the flat end of a spudger to disconnect the battery connector.
  18. Google Pixel 2 XL Charging Assembly Replacement, Motherboard: 18 단계, 이미지 1/2 Google Pixel 2 XL Charging Assembly Replacement, Motherboard: 18 단계, 이미지 2/2
    • Use the point of a spudger to disconnect the front-facing camera connector.
    • During reassembly, it's easiest to attach the front camera to the motherboard, then insert the motherboard.
  19. Google Pixel 2 XL Charging Assembly Replacement: 19 단계, 이미지 1/3 Google Pixel 2 XL Charging Assembly Replacement: 19 단계, 이미지 2/3 Google Pixel 2 XL Charging Assembly Replacement: 19 단계, 이미지 3/3
    • Use the flat end of a spudger to disconnect the right Active Edge sensor connector.
    • Disconnect the antenna cable.
  20. Google Pixel 2 XL Charging Assembly Replacement: 20 단계, 이미지 1/2 Google Pixel 2 XL Charging Assembly Replacement: 20 단계, 이미지 2/2
    • Use the point of a spudger to disconnect the fingerprint sensor connector.
  21. Google Pixel 2 XL Charging Assembly Replacement: 21 단계, 이미지 1/2 Google Pixel 2 XL Charging Assembly Replacement: 21 단계, 이미지 2/2
    • Use the flat end of a spudger to disconnect the left Active Edge sensor connector.
  22. Google Pixel 2 XL Charging Assembly Replacement: 22 단계, 이미지 1/2 Google Pixel 2 XL Charging Assembly Replacement: 22 단계, 이미지 2/2
    • Use the flat end of a spudger to disconnect the charging assembly connector.
  23. Google Pixel 2 XL Charging Assembly Replacement: 23 단계, 이미지 1/2 Google Pixel 2 XL Charging Assembly Replacement: 23 단계, 이미지 2/2
    • Use the point of a spudger to disconnect the front-facing sensor assembly connector.
  24. Google Pixel 2 XL Charging Assembly Replacement: 24 단계, 이미지 1/3 Google Pixel 2 XL Charging Assembly Replacement: 24 단계, 이미지 2/3 Google Pixel 2 XL Charging Assembly Replacement: 24 단계, 이미지 3/3
    • Make sure all the cables and connectors are clear of the board, and use the flat edge of a spudger to gently lift the bottom of the motherboard.
    • The narrow part of the motherboard is very fragile. If it starts to bend when you lift, stop and make sure there isn't anything holding the board down. The board should lift up without any resistance.
    • Holding the wide part of the motherboard near the SIM card slot, carefully slide the board toward the bottom of the phone while lifting it out of the phone.
    • Remove the motherboard.
    • Try to keep the phone flat with the battery facing up after you remove the motherboard, as the front-facing camera can fall out of the phone case very easily.
    • When reinstalling the motherboard, move all the cables and connectors out of the way of the board and make sure all connectors are aligned with their respective sockets.
  25. Google Pixel 2 XL Charging Assembly Replacement, Loudspeaker: 25 단계, 이미지 1/3 Google Pixel 2 XL Charging Assembly Replacement, Loudspeaker: 25 단계, 이미지 2/3 Google Pixel 2 XL Charging Assembly Replacement, Loudspeaker: 25 단계, 이미지 3/3
    • Slide the point of a spudger under the lower left side of the loudspeaker and slowly pry the speaker assembly up from the phone.
    • If you're having trouble, try inserting the flat end of a spudger into the gap at the base of the phone and slowly pry up.
  26. Google Pixel 2 XL Charging Assembly Replacement: 26 단계, 이미지 1/1
    • Remove the loudspeaker from the phone.
  27. Google Pixel 2 XL Charging Assembly Replacement, Charging Assembly: 27 단계, 이미지 1/3 Google Pixel 2 XL Charging Assembly Replacement, Charging Assembly: 27 단계, 이미지 2/3 Google Pixel 2 XL Charging Assembly Replacement, Charging Assembly: 27 단계, 이미지 3/3
    • Disconnect the white antenna cable.
    • Carefully pry the charging assembly out and remove it from the device.
    • The assembly is glued to the case so go slowly and be careful not to tear any cables. If the assembly does not come out easily, try heating the case where the board is glued.
결론
Lucas Rasmussen
회원 가입일: 04/23/18
2,323 평판
안내서 11개 작성하였습니다
Cal Poly, Team S7-G1, Paton Spring 2020 Cal Poly, Team S7-G1, Paton Spring 2020 회원
CPSU-PATON-S20S7G1
3 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 50
