소개
This is an outdated guide, go here for the newest version.
Use this guide to replace the rear camera in a Pixel 2 XL.
필요한 것
1 단계 Opening Procedure
주의: 1-12 단계들은 진행 중으로 표시된 안내서에서 제공되었습니다.
Apply a suction cup as close to the SIM slot edge of the phone as you can while avoiding the curved edge.
Do not insert the pick more than 0.25 inches (6 mm) into the bottom edge of the phone. If the pick contacts the folded portion of the OLED panel, it can damage the display.
Do not cut along the left edge; there are delicate display cables that can be damaged.
Only make very shallow cuts in the upper left corner; prying deeply can damage the front-facing camera.
이 단계에 사용된 도구:Magnetic Project Mat$19.95
Remove eleven 3.8 mm Phillips screws securing the midframe.
