소개
Prerequisite guide only! This guide is part of an another procedure and is not meant to be used alone.
Disconnects the antenna cables in preparation for motherboard removal.
필요한 것
Use the point of a spudger to pry up and disconnect the blue antenna cable from its socket on the charging assembly.
Use the point of a spudger to pry up and disconnect the black antenna cable from its socket near the USB-C port.
Carefully de-route both antenna cables and move them away from the charging assembly.
거의 끝나갑니다!
결론
