이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
Follow this guide to remove or replace the glass back cover for the Pixel 3. This procedure is necessary to access the Pixel’s internals.
필요한 것
Heat an iOpener and apply it to the bottom of the phone for one minute.
When prying above the power button, be careful not to insert the pick too deeply, or you will damage the fingerprint sensor cable.
Follow these steps if you need to transfer the fingerprint sensor to your replacement back cover.
Repair didn’t go as planned? Check out our Google Pixel 3 Answers community for troubleshooting help.
다른 27명이 해당 안내서를 완성하였습니다.
댓글 12개
My back cover would not come off by just using an iOpener. After getting a heat gun and applying the heat to the bottom corners I was able to get the adhesive weak enough to pry open.
Where can I buy all the tools needed to repair my Pixel 3?
How do you ensure the back cover is waterproof after putting it on? The precut adhesive card turns out just to be a roll of tesa tape, it would be nice if it actually had round cutouts, or large rectangular sections to custom cut to ensure water proofing around fingerprint sensor, and camera flash led.
Hi Daniel,
Unfortunately, there is no easy way to ensure water resistance after a repair, as the factory adhesive is applied using specialty tools. I’d suggest sealing it the best you can with adhesive and using a water resistant case.
On the adhesive product page, you can find the adhesive card under the first pull-down menu. The adhesive card does have rounded corners and cutouts for this purpose.
