이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Heat an iOpener and apply it to the bottom of the phone for one minute.
Apply a suction cup to the heated bottom edge of the back cover.
Lift on the suction cup with strong, steady force to create a gap.
Insert an opening pick into the gap.
Slice the adhesive along the bottom edge of the phone and around the right corner.
Leave a pick in the bottom edge to prevent the adhesive from re-sealing.
Heat the right edge with an iOpener and continue slicing the adhesive with an opening pick.
Continue heating and slicing through the rest of the phone perimeter. Leave a pick in each edge to prevent the adhesive from resealing.
Once you have sliced around the perimeter of the phone, carefully lift the left edge of the back cover.
Flip the back cover along its long axis and rest it so that the fingerprint sensor cable is not strained.
이 단계에 사용된 도구:Magnetic Project Mat$19.95-
Remove the two 4.1 mm-long Phillips screws securing the fingerprint connector bracket.
Use the point of a spudger to slide the fingerprint connector bracket out from under the NFC coil.
Remove the fingerprint connector bracket.
Use the point of a spudger to pry up and disconnect the fingerprint connector from its socket.
Remove the five Phillips screws securing the wireless charging coil:
Two 1.9 mm screws
Two 4.2 mm screws
One 4.3 mm screw
Use the point of a spudger to pry up and disconnect the battery press connector from its socket near the right edge of the phone.
Use the point of a spudger to pry up and disconnect the loudspeaker connector from its motherboard socket near the right edge of the phone.
Remove the following four Phillips screws:
One 1.9 mm screw
One 4.3 mm screw
Two 4.3 mm screws with thinner shanks
Remove the tiny grounding clip from the left screw hole. Be careful not to lose it.
Remove the small plastic insert from the right side of the USB-C port.
Insert the point of a spudger under the bottom right corner of the loudspeaker.
Pry up to loosen the loudspeaker from the phone.
Insert the point of a spudger under the top left corner of the loudspeaker.
Pry up to loosen the loudspeaker.
Insert the flat end of the spudger under the top edge of the loudspeaker, towards the left edge.
Remove the loudspeaker.
If it is in good condition, you can re-use the gasket. Make sure that the gasket does not cover the exit hole.
If the gasket is pulled out of place, remove it and replace the adhesive with a pre-cut strip or Tesa tape.
Use the point of a spudger to pry up and disconnect the blue antenna cable from its socket on the charging assembly.
Use the point of a spudger to carefully pry up and release the blue antenna cable from its grounding clip.
Use the point of a spudger to pry up and disconnect the black antenna cable from its socket near the USB-C port.
Carefully de-route both antenna cables and move them away from the charging assembly.
Use the point of a spudger to pry up and disconnect the charging assembly's connector from its motherboard socket, near the right edge of the phone.
Carefully peel the flex cable from the top of the SIM card reader.
Remove the two 1.9 mm Phillips screws securing the charging assembly to the bottom edge of the phone.
Apply a heated iOpener to the bottom edge of the phone for a minute to loosen the adhesive holding the charging assembly in place.
Insert an opening pick underneath the charging assembly's flex cable.
Slide the opening pick below the charging assembly to loosen it from the phone.
Use a pair of tweezers or your fingers to remove the charging assembly.
Be sure to remove all plastic liners from the assembly to expose the adhesive.
Line up the assembly's bottom left corner into place.
Carefully lay the rest of the assembly in place, making sure that the USB-C port is correctly seated in its respective cutout.
Use your fingers to press the assembly onto the frame.
다른 36명이 해당 안내서를 완성하였습니다.
댓글 11개
is the adhesive for the back of the phone reusable, or do I need to buy a replacement adhesive for reassembly?
It depends on the age of your phone it seems - the older the phone, the less resuseable the existing adhesive. I used gasket maker to reseal my phone, in part because I did not want to heat my new battery up when trying to reseal the back cover. I would advise getting some additional adhesive if you want a water-tight assembly.
Best to order a new back phone lid, as my back lid shattered when trying to prise it off, despite repeated heating to uncomfortably hot. Also, if you’re replacing the charging logic board because of the ‘unrecognised analogue device’ messsage, I still got the same message AFTER having put everything back together having replaced the logic board. If you shatter the back lid of the phone and have to replace it, the finger print scanner and lens covers are all prisable off and reapplicable to the new cover (with a little heating). But this requires care. Make sure to replace the battery also - because of the ka-fafel of opening this barely user-repairable phone (Cheers Google!). I ended up using gasket maker silicone (yes the stuff I use for reassembling my motorbike engine) to seal everything. Seems to have worked a treat. Good luck - you’ll need it!
I swapped out the USB-C charging port and battery at the same time. Hopefully I can get another two years out of the phone now. If you are just changing this port, then I would recommend changing the battery too. The battery replacement kit comes with new adhesive to reseal the back panel.
can I do this with a heat gun instead of the iOpener? what do I set the temperature to?
