주요 콘텐츠로 건너뛰기
이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
Google Pixel 3 Loudspeaker Replacement
필요한 것
  1. Google Pixel 3 Loudspeaker Replacement, Weaken the back cover's adhesive: 1 단계, 이미지 1/1
  2. Google Pixel 3 Loudspeaker Replacement, Create a gap in the seam: 2 단계, 이미지 1/3 Google Pixel 3 Loudspeaker Replacement, Create a gap in the seam: 2 단계, 이미지 2/3 Google Pixel 3 Loudspeaker Replacement, Create a gap in the seam: 2 단계, 이미지 3/3
    • Apply a suction cup to the heated bottom edge of the back cover.
    • Make sure you did not mistake the screen side for the back cover side.
    • If your back cover is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere.
    • Lift on the suction cup with strong, steady force to create a gap.
    • Depending on how aged your phone is, this may take significant force. If you are having trouble, apply more heat and try again.
    • Insert an opening pick into the gap.
    • Don't use metal tools to pry, or you'll mar or shatter the glass back cover. If the panel won't budge, apply more heat, either with a hair dryer or heat gun.
  3. Google Pixel 3 Loudspeaker Replacement, Fingerprint cable information: 3 단계, 이미지 1/1
    • When inserting an opening pick above the power button, be careful not to insert the pick too deeply, or you will damage the fingerprint sensor cable.
  4. Google Pixel 3 Loudspeaker Replacement, Cut through the adhesive: 4 단계, 이미지 1/3 Google Pixel 3 Loudspeaker Replacement, Cut through the adhesive: 4 단계, 이미지 2/3 Google Pixel 3 Loudspeaker Replacement, Cut through the adhesive: 4 단계, 이미지 3/3
    • Slice the adhesive along the bottom edge of the phone and around the right corner.
    • Leave a pick in the bottom edge to prevent the adhesive from re-sealing.
  5. Google Pixel 3 Loudspeaker Replacement: 5 단계, 이미지 1/3 Google Pixel 3 Loudspeaker Replacement: 5 단계, 이미지 2/3 Google Pixel 3 Loudspeaker Replacement: 5 단계, 이미지 3/3
    • Heat the right edge with an iOpener and continue slicing the adhesive with an opening pick.
    • The adhesive can be very gummy. Push the pick in and out in a sawing motion to help with slicing.
  6. Google Pixel 3 Loudspeaker Replacement: 6 단계, 이미지 1/3 Google Pixel 3 Loudspeaker Replacement: 6 단계, 이미지 2/3 Google Pixel 3 Loudspeaker Replacement: 6 단계, 이미지 3/3
    • Continue heating and slicing through the rest of the phone perimeter. Leave a pick in each edge to prevent the adhesive from resealing.
    • When slicing above the power button, do not insert the pick more than halfway in to avoid damaging the fingerprint sensor cable.
  7. Google Pixel 3 Loudspeaker Replacement, Lift the left edge of the back cover: 7 단계, 이미지 1/3 Google Pixel 3 Loudspeaker Replacement, Lift the left edge of the back cover: 7 단계, 이미지 2/3 Google Pixel 3 Loudspeaker Replacement, Lift the left edge of the back cover: 7 단계, 이미지 3/3
    • Once you have sliced around the perimeter of the phone, carefully lift the left edge of the back cover.
    • Do not attempt to remove the back cover. It is still attached to the phone by the fingerprint sensor cable.
    • Flip the back cover along its long axis and rest it so that the fingerprint sensor cable is not strained.
  8. Google Pixel 3 Loudspeaker Replacement, Remove the screws: 8 단계, 이미지 1/1
    이 단계에 사용된 도구:
    Magnetic Project Mat
    $19.95
    구매
    • Remove the two 4.1 mm-long Phillips screws securing the fingerprint connector bracket.
    • During reassembly, be careful not to over-tighten these screws, or you may damage your display.
  9. Google Pixel 3 Loudspeaker Replacement, Remove the fingerprint connector bracket: 9 단계, 이미지 1/3 Google Pixel 3 Loudspeaker Replacement, Remove the fingerprint connector bracket: 9 단계, 이미지 2/3 Google Pixel 3 Loudspeaker Replacement, Remove the fingerprint connector bracket: 9 단계, 이미지 3/3
    • Use the point of a spudger to slide the fingerprint connector bracket out from under the NFC coil.
    • Remove the fingerprint connector bracket.
  10. Google Pixel 3 Loudspeaker Replacement, Disconnect the fingerprint connector: 10 단계, 이미지 1/2 Google Pixel 3 Loudspeaker Replacement, Disconnect the fingerprint connector: 10 단계, 이미지 2/2
    • Use the point of a spudger to pry up and disconnect the fingerprint connector from its socket.
    • When you disconnect connectors like these, be careful not to dislodge the small surface-mounted components surrounding the socket.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  11. Google Pixel 3 Loudspeaker Replacement, Remove the back cover: 11 단계, 이미지 1/3 Google Pixel 3 Loudspeaker Replacement, Remove the back cover: 11 단계, 이미지 2/3 Google Pixel 3 Loudspeaker Replacement, Remove the back cover: 11 단계, 이미지 3/3
    • Remove the back cover.
    • Before you install a replacement back cover, be sure to remove all adhesive residue from the phone frame. Use an opening tool to scrape and high concentration isopropyl alcohol to clean the surface.
    • If you are re-using the back cover, be sure to clean off any adhesive, and apply new back cover adhesive.
    • If you are installing a replacement back cover, be sure to compare it with the original part. Transfer any remaining parts (such as the flash diffuser) over to your replacement part.
    • Follow this guide to correctly apply new back cover adhesive.
  12. Google Pixel 3 Loudspeaker Replacement, Remove the screws: 12 단계, 이미지 1/1
    • Remove the five Phillips screws securing the wireless charging coil:
    • Two 1.9 mm screws
    • Two 4.2 mm screws
    • One 4.3 mm screw
  13. Google Pixel 3 Loudspeaker Replacement, Remove the charging coil: 13 단계, 이미지 1/1
    • Lift up and remove the wireless charging coil.
  14. Google Pixel 3 Loudspeaker Replacement, Disconnect the battery cable: 14 단계, 이미지 1/2 Google Pixel 3 Loudspeaker Replacement, Disconnect the battery cable: 14 단계, 이미지 2/2
    • Use the point of a spudger to pry up and disconnect the battery press connector from its socket near the right edge of the phone.
  15. Google Pixel 3 Loudspeaker Replacement, Loudspeaker: 15 단계, 이미지 1/2 Google Pixel 3 Loudspeaker Replacement, Loudspeaker: 15 단계, 이미지 2/2
    • Use the point of a spudger to pry up and disconnect the loudspeaker connector from its motherboard socket near the right edge of the phone.
    • Be careful not to puncture the battery with the spudger.
  16. Google Pixel 3 Loudspeaker Replacement: 16 단계, 이미지 1/3 Google Pixel 3 Loudspeaker Replacement: 16 단계, 이미지 2/3 Google Pixel 3 Loudspeaker Replacement: 16 단계, 이미지 3/3
    • Remove the following four Phillips screws:
    • One 1.9 mm screw
    • One 4.3 mm screw
    • Two 4.3 mm screws with thinner shanks
    • Remove the tiny grounding clip from the left screw hole. Be careful not to lose it.
    • The grounding clip installs such that the contoured edge faces the left side of the phone.
    • Remove the small plastic insert from the right side of the USB-C port.
    • Be sure to reinstall this insert before you screw down the daughterboard.
  17. Google Pixel 3 Loudspeaker Replacement: 17 단계, 이미지 1/2 Google Pixel 3 Loudspeaker Replacement: 17 단계, 이미지 2/2
    • The loudspeaker is still held in place by a strong adhesive gasket. Before attempting to remove it, pry it up in a few different places to break the adhesive seal.
    • Insert the point of a spudger under the bottom right corner of the loudspeaker.
    • Pry up to loosen the loudspeaker from the phone.
  18. Google Pixel 3 Loudspeaker Replacement: 18 단계, 이미지 1/2 Google Pixel 3 Loudspeaker Replacement: 18 단계, 이미지 2/2
    • Insert the point of a spudger under the top left corner of the loudspeaker.
    • Pry up to loosen the loudspeaker.
  19. Google Pixel 3 Loudspeaker Replacement: 19 단계, 이미지 1/2 Google Pixel 3 Loudspeaker Replacement: 19 단계, 이미지 2/2
    • Insert the flat end of the spudger under the top edge of the loudspeaker, towards the left edge.
  20. Google Pixel 3 Loudspeaker Replacement: 20 단계, 이미지 1/2 Google Pixel 3 Loudspeaker Replacement: 20 단계, 이미지 2/2
    • Remove the loudspeaker.
    • Before you install a replacement loudspeaker, check the adhesive gasket.
    • If it is in good condition, you can re-use the gasket. Make sure that the gasket does not cover the exit hole.
    • If the gasket is pulled out of place, remove it and replace the adhesive with a pre-cut strip or Tesa tape.
결론
Repair didn’t go as planned? Check out our Google Pixel 3 Answers community for troubleshooting help.
다른 4명이 해당 안내서를 완성하였습니다.
Arthur Shi
회원 가입일: 01/03/18
252,733 평판
안내서 526개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 16,817개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 9
30일 전: 54
전체 시간: 7,291
