주요 콘텐츠로 건너뛰기
소개
This guide shows how to remove and replace the plastic flash diffuser on your Pixel 3 XL.
  1. Heat an iOpener and apply it to the right edge of the back panel for a minute. A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage. While you wait, note the following areas on the back panel:
    • Heat an iOpener and apply it to the right edge of the back panel for a minute.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
    • While you wait, note the following areas on the back panel:
    • Strong adhesive—there are large patches of adhesive near the bottom of the phone.
    • Fingerprint sensor cable—be careful not to slice through the cable as you pry
  2. Apply a suction cup to the heated edge of the back panel, as close to the edge as possible. Pull up on the suction cup with strong, steady force to create a gap. Depending on the age of your phone, this may be difficult. If you are having trouble, apply heat to the edge and try again.
    • Apply a suction cup to the heated edge of the back panel, as close to the edge as possible.
    • Pull up on the suction cup with strong, steady force to create a gap.
    • Depending on the age of your phone, this may be difficult. If you are having trouble, apply heat to the edge and try again.
    • Insert the point of an opening pick into the gap.
  3. Slide the opening pick along the right edge to slice through the adhesive. The adhesive gums up and becomes hard to slice once it cools. If that happens, re-apply heat to the edge to make slicing easier. Once you have sliced through the edge, leave an opening pick in the seam to prevent the adhesive from re-sealing.
    • Slide the opening pick along the right edge to slice through the adhesive.
    • The adhesive gums up and becomes hard to slice once it cools. If that happens, re-apply heat to the edge to make slicing easier.
    • Once you have sliced through the edge, leave an opening pick in the seam to prevent the adhesive from re-sealing.
  4. Apply a heated iOpener to the bottom of the back panel for a minute.
    • Apply a heated iOpener to the bottom of the back panel for a minute.
  5. Use an opening pick to slice around the bottom right corner and continue along the bottom edge of the phone. Work slowly as you slice around the corner to prevent the panel from cracking. If the slicing becomes hard, re-apply heat. Leave a pick in the edge to prevent the adhesive from re-sealing.
    • Use an opening pick to slice around the bottom right corner and continue along the bottom edge of the phone.
    • Work slowly as you slice around the corner to prevent the panel from cracking. If the slicing becomes hard, re-apply heat.
    • Leave a pick in the edge to prevent the adhesive from re-sealing.
  6. Continue heating and slicing the remaining edges of the phone. Be careful as you slice along the left edge of the phone. If your pick feels like it's stuck near the top, you may have snagged the fingerprint sensor. Retract the pick out of the seam slightly and try again. Be sure to cut through the thick portions of adhesive near the bottom and right edge of the phone.
    • Continue heating and slicing the remaining edges of the phone.
    • Be careful as you slice along the left edge of the phone. If your pick feels like it's stuck near the top, you may have snagged the fingerprint sensor. Retract the pick out of the seam slightly and try again.
    • Be sure to cut through the thick portions of adhesive near the bottom and right edge of the phone.
  7. Gently pry up the right edge of the back panel.
    • Gently pry up the right edge of the back panel.
    • Use an opening pick to slice through any remaining adhesive along the edges.
  8. Swing the right edge of the back panel upwards and rest the flipped panel along the left side of the phone. Be sure to maintain slack on the fingerprint sensor cable and prevent it from being pinched. During reassembly, this is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
    • Swing the right edge of the back panel upwards and rest the flipped panel along the left side of the phone.
    • Be sure to maintain slack on the fingerprint sensor cable and prevent it from being pinched.
    • During reassembly, this is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
    • During reassembly, follow this guide to install custom-cut adhesives for your back panel.
  9. User tweezers to carefully peel up and remove the yellow tape over the fingerprint sensor connector.
    • User tweezers to carefully peel up and remove the yellow tape over the fingerprint sensor connector.
  10. Use the point of a spudger to carefully flip up the black lock bar on the fingerprint sensor's ZIF socket. Grasp the cable's tab with your fingers or tweezers and gently walk the flex cable out of the socket. To prevent shorting, be careful not to touch the metal contacts on the flex cable with your tweezers.
    • Use the point of a spudger to carefully flip up the black lock bar on the fingerprint sensor's ZIF socket.
    • Grasp the cable's tab with your fingers or tweezers and gently walk the flex cable out of the socket.
    • To prevent shorting, be careful not to touch the metal contacts on the flex cable with your tweezers.
  11. Remove the back panel.
    • Remove the back panel.
  12. Insert the edge of an opening tool underneath the plastic flash diffuser and slowly pry up to loosen the diffuser.
    • Insert the edge of an opening tool underneath the plastic flash diffuser and slowly pry up to loosen the diffuser.
    • Remove the diffuser.
결론
Repair didn’t go as planned? Ask our Answers community for help.
Arthur Shi
회원 가입일: 2018년 01월 03일
167,356 평판
안내서 411개 작성하였습니다
iFixit iFixit 회원
Community
136 회원들
안내서 16,682개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 12
전체 시간: 433
