주요 콘텐츠로 건너뛰기
Google Pixel 3a Plastic Midframe Replacement
단지 전제 조건
이 안내서는 다른 가이드의 선행 작업으로 사용하기 위한 것입니다. 그 자체로는 불완전합니다.
필요한 것
  1. Google Pixel 3a Plastic Midframe Replacement, Plastic Midframe: 1 단계, 이미지 1/1
    이 단계에 사용된 도구:
    Magnetic Project Mat
    $19.95
    구매
    • Remove the fourteen T3 screws of the following lengths securing the plastic midframe:
    • Twelve 4.3 mm silver T3 screws
    • Two 4.3 mm black T3 screws
  2. Google Pixel 3a Plastic Midframe Replacement: 2 단계, 이미지 1/3 Google Pixel 3a Plastic Midframe Replacement: 2 단계, 이미지 2/3 Google Pixel 3a Plastic Midframe Replacement: 2 단계, 이미지 3/3
    • The midframe is still held in place by plastic clips.
    • Insert an opening pick into frame seam at the bottom of the phone. This seam sits between the plastic midframe and the back cover.
    • Slide the pick along the seam to release the clips holding the plastic midframe.
  3. Google Pixel 3a Plastic Midframe Replacement: 3 단계, 이미지 1/3 Google Pixel 3a Plastic Midframe Replacement: 3 단계, 이미지 2/3 Google Pixel 3a Plastic Midframe Replacement: 3 단계, 이미지 3/3
    • Slide the opening pick along the left and right edges of the phone to release the midframe clips.
    • Lift the bottom edge of the plastic midframe up but do not remove the midframe. The midframe is still tethered to the phone by the fragile proximity sensor cable at the top edge.
    • To reinstall the plastic midframe, align the midframe to the back cover, and squeeze the perimeter of the phone with your fingers to snap the clips back into position.
  4. Google Pixel 3a Plastic Midframe Replacement: 4 단계, 이미지 1/3 Google Pixel 3a Plastic Midframe Replacement: 4 단계, 이미지 2/3 Google Pixel 3a Plastic Midframe Replacement: 4 단계, 이미지 3/3
    • Use the point of a spudger to carefully pry up and disconnect the proximity sensor connector from the motherboard.
    • Your proximity sensor connector may have automatically disconnected itself when you lifted the midframe.
    • Remove the plastic midframe.
  5. Google Pixel 3a Plastic Midframe Replacement: 5 단계, 이미지 1/3 Google Pixel 3a Plastic Midframe Replacement: 5 단계, 이미지 2/3 Google Pixel 3a Plastic Midframe Replacement: 5 단계, 이미지 3/3
    • This step shows how to reconnect the proximity sensor during re-assembly.
    • Align the top edge of the plastic midframe with the phone.
    • Use the point of a spudger to carefully align and push the proximity sensor connector onto the motherboard socket.
    • This takes a bit of patience and finesse. Once you have the connector in place, you can also use a finger to gently press the connector onto the socket.
    • Alternatively, you can remove the proximity sensor from the midframe to reattach it to the motherboard first.
    • Use the point of a spudger to carefully pry the proximity sensor out of its recess on the midframe. The sensor is lightly adhered to the midframe.
    • Remove the sensor from the midframe. Attach the sensor connector onto its motherboard socket.
    • Thread the sensor cable through the midframe and reposition the sensor in the recess. Press down with your finger to adhere the sensor back onto the midframe.
결론
Arthur Shi
회원 가입일: 01/03/18
252,468 평판
안내서 526개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 16,757개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 100
