주요 콘텐츠로 건너뛰기
  1. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Insert a SIM eject tool, bit, or straightened paper clip into the SIM card tray hole. The SIM card tray is located on the left edge of the phone near the bottom. Press firmly to eject the SIM card tray.
    • Insert a SIM eject tool, bit, or straightened paper clip into the SIM card tray hole.
    • The SIM card tray is located on the left edge of the phone near the bottom.
    • Press firmly to eject the SIM card tray.
    • Remove the SIM card tray.
  2. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Heat an iOpener and apply it to the bottom edge of the screen for one minute.
    • Heat an iOpener and apply it to the bottom edge of the screen for one minute.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  3. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Apply a suction cup to the screen, as close to the heated edge as possible. If your screen is badly cracked, follow this guide  to tape over the cracked screen. If all else fails, you can superglue the suction cup to the broken screen. Pull up on the suction cup with strong, steady force to create a gap.
    • Apply a suction cup to the screen, as close to the heated edge as possible.
    • If your screen is badly cracked, follow this guide to tape over the cracked screen. If all else fails, you can superglue the suction cup to the broken screen.
    • Pull up on the suction cup with strong, steady force to create a gap.
    • Depending on the age of your device, this may be difficult. If you have trouble, apply more heat and try again.
    • Insert the opening pick into the gap.
  4. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Slide the opening pick back and forth along the bottom of the screen to slice the adhesive. Leave the pick inserted in the bottom right corner to prevent the adhesive from re-sealing. Leave the pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
    • Slide the opening pick back and forth along the bottom of the screen to slice the adhesive.
    • Leave the pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
  5. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Apply a heated iOpener to the left edge of the screen for one minute.
    • Apply a heated iOpener to the left edge of the screen for one minute.
  6. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Insert another opening pick into the bottom left corner of the screen. Slide the opening pick around the left corner. Do not insert the pick more than 1/4 inch (6 mm)  or you may damage the screen's flex cable located in the middle of the left edge.
    • Insert another opening pick into the bottom left corner of the screen.
    • Slide the opening pick around the left corner.
    • Do not insert the pick more than 1/4 inch (6 mm) or you may damage the screen's flex cable located in the middle of the left edge.
    • Continue to slide the pick up towards the front camera to slice the adhesive on the left edge of the screen.
    • Leave the pick inserted to prevent the adhesive from re-sealing.
  7. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Insert another opening pick into the top left corner of the screen. Slide the pick around the front camera and across the top edge of the phone. If the adhesive is difficult to slice, apply heat to the area for one minute and try again.
    • Insert another opening pick into the top left corner of the screen.
    • Slide the pick around the front camera and across the top edge of the phone.
    • If the adhesive is difficult to slice, apply heat to the area for one minute and try again.
    • Slide the pick to the top right corner of the phone and leave the pick inserted.
  8. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Insert an opening pick into the bottom right corner of the screen. Slide the pick up to the top right corner to slice the last edge of adhesive. You may need to run an opening pick around the edges again to ensure all the adhesive is cut. It is applied the thickest on the four corners.
    • Insert an opening pick into the bottom right corner of the screen.
    • Slide the pick up to the top right corner to slice the last edge of adhesive.
    • You may need to run an opening pick around the edges again to ensure all the adhesive is cut. It is applied the thickest on the four corners.
  9. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Use the opening pick from the top left corner to lift up the left edge of the screen a few millimeters. This will keep the clips from snapping back down into the case. Lift up on the right side of the screen and open up the phone like a book.
    • Use the opening pick from the top left corner to lift up the left edge of the screen a few millimeters. This will keep the clips from snapping back down into the case.
    • Lift up on the right side of the screen and open up the phone like a book.
    • Do not open the screen more than 90 degrees to prevent damaging the screen flex cable.
  10. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Use tweezers to grip the screen connector cover securing the screen flex cable. Push the clip in towards the connector to unlatch it.
    • Use tweezers to grip the screen connector cover securing the screen flex cable.
    • Push the clip in towards the connector to unlatch it.
  11. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Remove the screen connector cover. Make sure to keep this component to reinstall it during reassembly.
    • Remove the screen connector cover.
    • Make sure to keep this component to reinstall it during reassembly.
  12. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Use the tip of the spudger to pry up and disconnect the screen flex cable. To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage
    • Use the tip of the spudger to pry up and disconnect the screen flex cable.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage
  13. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Remove the screen. Use tweezers to pick off the remaining adhesive on the case.
    • Remove the screen.
    • Use tweezers to pick off the remaining adhesive on the case.
    • If your replacement screen's display cable is held down by tape, remove the tape before installation.
    • If you are using a custom-cut adhesive, follow this guide for instructions on how to apply adhesive to the replacement screen.
    • If you are using Tesa tape to reattach the screen, follow this guide.
    • During the boot-up process after reassembly, the screen will go through a calibration sequence. Do not touch the screen during this process, as it could result in improper touch calibration and create touch issues.
    • If you use isopropyl alcohol to clean the adhesive off the display, be sure to not let it splash onto any unintended components, as this can weaken their adhesive bond.
  14. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Use tweezers to lift up the graphite tape until you are able to grip it with your fingers. Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a thermal event. Peel off the graphite tape.
    • Use tweezers to lift up the graphite tape until you are able to grip it with your fingers.
    • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a thermal event.
    • Peel off the graphite tape.
  15. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Use tweezers to peel off the graphite pad covering the charging plate cover. If you are able to keep the graphite pad in good condition, you may reapply it during reassembly.
    • Use tweezers to peel off the graphite pad covering the charging plate cover.
    • If you are able to keep the graphite pad in good condition, you may reapply it during reassembly.
  16. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    • Use a T3 Torx driver to remove the two 4.6 mm-long screws securing the charging plate cover to the midframe.
  17. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Use tweezers to remove the charging plate cover. Make sure to keep this component to reinstall it during reassembly.
    • Use tweezers to remove the charging plate cover.
  18. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Use a T3 Torx driver to remove the eight 4.6 mm-long screws securing the midframe.
    • Use a T3 Torx driver to remove the eight 4.6 mm-long screws securing the midframe.
  19. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Use tweezers to lift up the right side of the midframe. Remove the midframe. Remove the midframe.
    • Use tweezers to lift up the right side of the midframe.
    • Remove the midframe.
  20. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Use the pointed end of the spudger to pry the battery connector straight up and disconnect it from the motherboard. Use the pointed end of the spudger to pry the battery connector straight up and disconnect it from the motherboard.
    • Use the pointed end of the spudger to pry the battery connector straight up and disconnect it from the motherboard.
  21. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Use a T3 Torx driver to remove the 4.1 mm shouldered screw.
    • Use a T3 Torx driver to remove the 4.1 mm shouldered screw.
  22. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Use the spudger to disconnect the two rear camera press connectors from the motherboard. Use your finger to hold down the rear camera assembly and prevent bending the motherboard. Use your finger to hold down the rear camera assembly and prevent bending the motherboard.
    • Use the spudger to disconnect the two rear camera press connectors from the motherboard.
    • Use your finger to hold down the rear camera assembly and prevent bending the motherboard.
  23. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Use tweezers to lift up on the rear camera assembly to remove it from its housing. If your replacement camera module has a plastic spacer, be sure to remove it before you install the module. Make sure the lens surface is smudge and dust free before you install the camera assembly.
    • Use tweezers to lift up on the rear camera assembly to remove it from its housing.
    • If your replacement camera module has a plastic spacer, be sure to remove it before you install the module.
    • Make sure the lens surface is smudge and dust free before you install the camera assembly.
  24. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Use blunt nose tweezers to grip the black adhesive pull tab located on the top right edge of the battery. Lift the pull tab with the tweezers until you are able to grip it with your fingers. Pull on the pull tab with a slow, steady force at a shallow angle to prevent the pull tab from snapping in the middle. Try to keep the adhesive strips flat and unwrinkled during this procedure; twisted or wrinkled strips will stick together and break instead of pulling out cleanly.
    • Use blunt nose tweezers to grip the black adhesive pull tab located on the top right edge of the battery. Lift the pull tab with the tweezers until you are able to grip it with your fingers.
    • Pull on the pull tab with a slow, steady force at a shallow angle to prevent the pull tab from snapping in the middle.
    • Try to keep the adhesive strips flat and unwrinkled during this procedure; twisted or wrinkled strips will stick together and break instead of pulling out cleanly.
    • If the adhesive becomes hard to pull, you can roll it around a spudger and continue pulling.
    • If the pull tab breaks prematurely, use tweezers to retrieve the remaining length of adhesive and continue pulling.
    • If you are unable to retrieve it, move on to the next step.
  25. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Use the same process to remove the pull tab located at the bottom left edge of the battery. If this tab breaks prematurely and you are not able to retrieve it with tweezers, move on to the next step. If this tab breaks prematurely and you are not able to retrieve it with tweezers, move on to the next step.
    • Use the same process to remove the pull tab located at the bottom left edge of the battery.
    • If this tab breaks prematurely and you are not able to retrieve it with tweezers, move on to the next step.
  26. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    If any of the adhesive strips broke off underneath the battery and could not be retrieved, apply a few drops of high concentration (over 90%) isopropyl alcohol into the opening of the affected tab. If any of the adhesive strips broke off underneath the battery and could not be retrieved, apply a few drops of high concentration (over 90%) isopropyl alcohol into the opening of the affected tab.
    • If any of the adhesive strips broke off underneath the battery and could not be retrieved, apply a few drops of high concentration (over 90%) isopropyl alcohol into the opening of the affected tab.
  27. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Tilt the phone so that the alcohol flows towards the remaining adhesive. Wait one minute for the adhesive to soften, then proceed to the next step.
    • Tilt the phone so that the alcohol flows towards the remaining adhesive.
    • Wait one minute for the adhesive to soften, then proceed to the next step.
  28. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Insert an opening pick into the gap long the left side of the battery. Use the opening pick to slice the remaining adhesive at the top and bottom of the battery.
    • Insert an opening pick into the gap long the left side of the battery.
    • Use the opening pick to slice the remaining adhesive at the top and bottom of the battery.
    • Avoid scraping the two flex cables under the battery with your opening pick.
    • This may be difficult as the adhesive is strategically located between the cables and the battery tray. A possible solution is to cut a plastic card to fit between the flex cables and battery tray edge.
    • Do not bend the battery.
    • Avoid the earpiece contact pins located near the top left corner of the battery as you pry up with your opening pick.
    • If you cannot pry the battery up, add a few more drops of isopropyl alcohol to the adhesive. A plastic card can also be helpful during this process.
  29. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Do not reuse the battery if it has been deformed or damaged, as doing so is a potential safety hazard. Replace it with a new battery. Remove your old battery.
    • Do not reuse the battery if it has been deformed or damaged, as doing so is a potential safety hazard. Replace it with a new battery.
    • Remove your old battery.
  30. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Use the pointed end of a spudger to disconnect the two press connectors by lifting them straight up from the motherboard. Use the pointed end of a spudger to disconnect the two press connectors by lifting them straight up from the motherboard. Use the pointed end of a spudger to disconnect the two press connectors by lifting them straight up from the motherboard.
    • Use the pointed end of a spudger to disconnect the two press connectors by lifting them straight up from the motherboard.
  31. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Use a T3 Torx driver to remove the two 2.9 mm screws securing the motherboard to the rear case.
    • Use a T3 Torx driver to remove the two 2.9 mm screws securing the motherboard to the rear case.
  32. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Use a spudger to gently fold the flex cable covering the rear case press connector out of the way. Use a spudger to gently fold the flex cable covering the rear case press connector out of the way. Use a spudger to gently fold the flex cable covering the rear case press connector out of the way.
    • Use a spudger to gently fold the flex cable covering the rear case press connector out of the way.
  33. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Use the spudger to disconnect the rear case press connector. Use the spudger to disconnect the rear case press connector.
    • Use the spudger to disconnect the rear case press connector.
  34. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Insert the pointed end of the spudger into the screw holes near the front facing camera. Push the motherboard down towards the bottom of the phone, then lift up to free the top of the motherboard from the rear case.
    • Insert the pointed end of the spudger into the screw holes near the front facing camera.
    • Push the motherboard down towards the bottom of the phone, then lift up to free the top of the motherboard from the rear case.
  35. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Use your fingers to pull the motherboard up towards the top of the rear case to free the charging port. Do not bend or twist the motherboard. If the motherboard gets caught on the case, use a spudger to go around the edges and loosen it up.
    • Use your fingers to pull the motherboard up towards the top of the rear case to free the charging port.
    • Do not bend or twist the motherboard.
    • If the motherboard gets caught on the case, use a spudger to go around the edges and loosen it up.
    • Remove the motherboard.
  36. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    After removing the motherboard, the top spacer may fall out of place. Remember to replace this spacer before you reseal your phone. Grip the antenna by the body and not by the delicate end tabs.
    • After removing the motherboard, the top spacer may fall out of place. Remember to replace this spacer before you reseal your phone.
    • Grip the antenna by the body and not by the delicate end tabs.
결승점
Robert Boyd
회원 가입일: 2021년 02월 01일
18,354 평판
안내서 90개 작성하였습니다
iFixit iFixit 회원
Community
142 회원들
안내서 16,792개 작성하였습니다
댓글 한 개
Good day. Please tell me, what is the size of the vibration motor for the pixel 5? I can't find the type of vibro motor anywhere.
Андрей Тарасенко - 답글
댓글 쓰기
조회 통계:
24 시간 전: 14
7일 전: 114
30일 전: 414
전체 시간: 4,139
