주요 콘텐츠로 건너뛰기
Google Pixel 6 Camera Glass Panel Replacement
필요한 것
  1. Google Pixel 6 Camera Glass Panel Replacement, Camera Glass Panel: 1 단계, 이미지 2개 중 1개 Google Pixel 6 Camera Glass Panel Replacement, Camera Glass Panel: 1 단계, 이미지 2개 중 2개
    • Use the wet wipe included in your kit to clean the rear camera glass panel.
    • Dry off the rear camera glass panel with the dry wipe.
  2. Google Pixel 6 Camera Glass Panel Replacement: 2 단계, 이미지 2개 중 1개 Google Pixel 6 Camera Glass Panel Replacement: 2 단계, 이미지 2개 중 2개
    • Carefully cut around the edges of the phone's rear glass panel using an X-Acto knife.
    • Caution: Hazardous situation which involves a sharp utensil and glass fragments.
  3. Google Pixel 6 Camera Glass Panel Replacement: 3 단계, 이미지 2개 중 1개 Google Pixel 6 Camera Glass Panel Replacement: 3 단계, 이미지 2개 중 2개
    • Using the tweezers, begin chipping and tweezing away at the cracked region.
    • Caution: Shards and shrapnel can splinter off of the panel.
    • Keep some masking tape near to be able to pick up shrapnel without injuring yourself.
  4. Google Pixel 6 Camera Glass Panel Replacement: 4 단계, 이미지 3개 중 1개 Google Pixel 6 Camera Glass Panel Replacement: 4 단계, 이미지 3개 중 2개 Google Pixel 6 Camera Glass Panel Replacement: 4 단계, 이미지 3개 중 3개
    • Use the metal spudger to remove the larger pieces of the glass to expose the layer underneath.
    • Caution: Hastily removing sharp fragments pieces could result in injury.
  5. Google Pixel 6 Camera Glass Panel Replacement: 5 단계, 이미지 2개 중 1개 Google Pixel 6 Camera Glass Panel Replacement: 5 단계, 이미지 2개 중 2개
    • Use the opening tool to remove excess glue leftover from the old glass panel.
    • Perform this step only when all glass has been removed from the camera area.
  6. Google Pixel 6 Camera Glass Panel Replacement: 6 단계, 이미지 3개 중 1개 Google Pixel 6 Camera Glass Panel Replacement: 6 단계, 이미지 3개 중 2개 Google Pixel 6 Camera Glass Panel Replacement: 6 단계, 이미지 3개 중 3개
    • Take a piece of masking tape about 3 inches wide.
    • Gently press the masking tape (sticky side down) onto the rear camera lens and lift, removing the glass debris.
    • Repeat until most of the glass debris is removed.
  7. Google Pixel 6 Camera Glass Panel Replacement: 7 단계, 이미지 3개 중 1개 Google Pixel 6 Camera Glass Panel Replacement: 7 단계, 이미지 3개 중 2개 Google Pixel 6 Camera Glass Panel Replacement: 7 단계, 이미지 3개 중 3개
    • Align the glass panel replacement with the exposed camera area.
    • Press the glass panel firmly into the camera area.
    • Do not press too hard to avoid cracking glass from excess pressure.
    • Let the glass panel adhesive dry for approximately two hours before using the phone.
결승점
작성자
3다른 기여자 명과 함께
Aliyah Sims
회원 가입일: 02/19/25
145 평판
안내서 1개를 작성함
UC Davis, Team 1-6, Andersen Winter 2025 UC Davis, Team 1-6, Andersen Winter 2025 회원
UCD-ANDERSEN-W25S1G6
3 회원들
안내서 1개 작성
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 33
지난 30일: 116
전체 시간: 1,063
