주요 콘텐츠로 건너뛰기
Google Pixel 9 Pro Fold Outer Front Camera Replacement
필요한 것
  1. Google Pixel 9 Pro Fold Outer Front Camera Replacement, Prepare your phone for disassembly: 1 단계, 이미지 1개 중 1개
    • Let your phone's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables from your phone and completely power it down.
  2. Google Pixel 9 Pro Fold Outer Front Camera Replacement, Insert an opening pick: 2 단계, 이미지 3개 중 1개 Google Pixel 9 Pro Fold Outer Front Camera Replacement, Insert an opening pick: 2 단계, 이미지 3개 중 2개 Google Pixel 9 Pro Fold Outer Front Camera Replacement, Insert an opening pick: 2 단계, 이미지 3개 중 3개
    • Apply a suction cup to the screen, as close to the center of the bottom edge as possible.
    • Pull up on the suction cup with strong, steady force to create a gap between the screen and the frame.
    • Insert an opening pick into the gap.
    • If your screen is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the screen.
  3. Google Pixel 9 Pro Fold Outer Front Camera Replacement, Separate the adhesive: 3 단계, 이미지 3개 중 1개 Google Pixel 9 Pro Fold Outer Front Camera Replacement, Separate the adhesive: 3 단계, 이미지 3개 중 2개 Google Pixel 9 Pro Fold Outer Front Camera Replacement, Separate the adhesive: 3 단계, 이미지 3개 중 3개
    • During the next four steps, don't insert your opening pick deeper than 3 mm to prevent damaging internal components.
    • Optionally, you can measure and mark your opening pick 3 mm from the tip to help you visualize the length.
    • Slide the opening pick around the bottom right corner and up the right edge of the screen to separate the adhesive.
  4. Google Pixel 9 Pro Fold Outer Front Camera Replacement: 4 단계, 이미지 3개 중 1개 Google Pixel 9 Pro Fold Outer Front Camera Replacement: 4 단계, 이미지 3개 중 2개 Google Pixel 9 Pro Fold Outer Front Camera Replacement: 4 단계, 이미지 3개 중 3개
    • Slide the pick around the top right corner and stop before the front camera.
  5. Google Pixel 9 Pro Fold Outer Front Camera Replacement: 5 단계, 이미지 3개 중 1개 Google Pixel 9 Pro Fold Outer Front Camera Replacement: 5 단계, 이미지 3개 중 2개 Google Pixel 9 Pro Fold Outer Front Camera Replacement: 5 단계, 이미지 3개 중 3개
    • Pull the opening pick out so only the tip is under the screen.
    • Slide the opening pick across the top edge of the screen until you're past the front camera.
    • Push your pick to its original depth before continuing.
  6. Google Pixel 9 Pro Fold Outer Front Camera Replacement: 6 단계, 이미지 3개 중 1개 Google Pixel 9 Pro Fold Outer Front Camera Replacement: 6 단계, 이미지 3개 중 2개 Google Pixel 9 Pro Fold Outer Front Camera Replacement: 6 단계, 이미지 3개 중 3개
    • Slide the opening pick around the top left corner and stop about two‑thirds down the left edge of the screen.
    • Don't slide the pick any farther, or you risk damaging the display cable.
  7. Google Pixel 9 Pro Fold Outer Front Camera Replacement: 7 단계, 이미지 3개 중 1개 Google Pixel 9 Pro Fold Outer Front Camera Replacement: 7 단계, 이미지 3개 중 2개 Google Pixel 9 Pro Fold Outer Front Camera Replacement: 7 단계, 이미지 3개 중 3개
    • Pull the opening pick out to a 2 mm depth and rotate the pick around the bottom left corner to separate the remaining adhesive.
  8. Google Pixel 9 Pro Fold Outer Front Camera Replacement: 8 단계, 이미지 3개 중 1개 Google Pixel 9 Pro Fold Outer Front Camera Replacement: 8 단계, 이미지 3개 중 2개 Google Pixel 9 Pro Fold Outer Front Camera Replacement: 8 단계, 이미지 3개 중 3개
    • Don't fully remove the screen yet, as it's still connected to the phone by a cable.
    • At this point, the screen should be free from the frame. If there's still resistance around the edges, use an opening pick to separate any remaining adhesive.
    • Lift the right edge of the screen and swing it over the left edge of the phone, like opening a book.
    • Prop up the screen with your suction handle or a clean, sturdy object.
  9. Google Pixel 9 Pro Fold Outer Front Camera Replacement, Remove the display cable bracket screw: 9 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Outer Front Camera Replacement, Remove the display cable bracket screw: 9 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    FixMat
    $31.41
    • While the Pixel 9 Pro Fold uses Torx Plus screws, standard Torx bits also work. Use the same size or one size larger (T3 or T4 Torx bits with 3IP Torx Plus screws) and apply constant, downward force to prevent stripping.
    • Use a Torx Plus 3IP driver to remove the 2.2 mm‑long screw securing the display cable bracket.
  10. Google Pixel 9 Pro Fold Outer Front Camera Replacement: 10 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Outer Front Camera Replacement: 10 단계, 이미지 2개 중 2개
    • Conductive tape secures the display cable bracket to the frame.
    • Use a spudger, or your fingers, to lift the display cable bracket enough to access the press connector underneath.
  11. Google Pixel 9 Pro Fold Outer Front Camera Replacement, Disconnect the display cable: 11 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Outer Front Camera Replacement, Disconnect the display cable: 11 단계, 이미지 2개 중 2개
    • Use the point of a spudger to pry up and disconnect the display cable press connector.
  12. Google Pixel 9 Pro Fold Outer Front Camera Replacement, Remove the screen: 12 단계, 이미지 1개 중 1개
    • Lift the screen off the frame and remove it.
  13. Google Pixel 9 Pro Fold Outer Front Camera Replacement, Remove the battery bracket screw: 13 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Outer Front Camera Replacement, Remove the battery bracket screw: 13 단계, 이미지 2개 중 2개
    • Use a Torx Plus 3IP driver to remove the 2.0 mm‑long screw securing the battery bracket.
  14. Google Pixel 9 Pro Fold Outer Front Camera Replacement, Disconnect the battery: 14 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Outer Front Camera Replacement, Disconnect the battery: 14 단계, 이미지 2개 중 2개
    • Conductive tape secures the battery connector bracket to the lower board.
    • Use tweezers, or your fingers, to move the battery bracket out of the way of the battery press connector.
  15. Google Pixel 9 Pro Fold Outer Front Camera Replacement: 15 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Outer Front Camera Replacement: 15 단계, 이미지 2개 중 2개
    • Use the point of a spudger to pry up and disconnect the battery press connector.
  16. Google Pixel 9 Pro Fold Outer Front Camera Replacement, Remove the rubber block: 16 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Outer Front Camera Replacement, Remove the rubber block: 16 단계, 이미지 2개 중 2개
    • Use tweezers, or your fingers, to remove the rubber block covering a screw on the top board.
  17. Google Pixel 9 Pro Fold Outer Front Camera Replacement, Remove the top interconnect cable bracket screws: 17 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Outer Front Camera Replacement, Remove the top interconnect cable bracket screws: 17 단계, 이미지 2개 중 2개
    • Use a Torx Plus 3IP driver to remove the two 2.2 mm‑long screws securing the top interconnect cable bracket.
  18. Google Pixel 9 Pro Fold Outer Front Camera Replacement, Remove the top interconnect cable bracket: 18 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Outer Front Camera Replacement, Remove the top interconnect cable bracket: 18 단계, 이미지 2개 중 2개
    • Use tweezers, or your fingers, to remove the top interconnect cable bracket.
  19. Google Pixel 9 Pro Fold Outer Front Camera Replacement, Disconnect the top interconnect cable: 19 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Outer Front Camera Replacement, Disconnect the top interconnect cable: 19 단계, 이미지 2개 중 2개
    • Insert the point of a spudger under the top right corner of the top interconnect cable press connector, near the golden marker.
    • Pry up and disconnect the top interconnect cable press connector.
  20. Google Pixel 9 Pro Fold Outer Front Camera Replacement, Remove the top board screw: 20 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Outer Front Camera Replacement, Remove the top board screw: 20 단계, 이미지 2개 중 2개
    • Use a Torx Plus 3IP driver to remove the 2.2 mm‑long screw securing the top board.
  21. Google Pixel 9 Pro Fold Outer Front Camera Replacement, Remove the top board: 21 단계, 이미지 3개 중 1개 Google Pixel 9 Pro Fold Outer Front Camera Replacement, Remove the top board: 21 단계, 이미지 3개 중 2개 Google Pixel 9 Pro Fold Outer Front Camera Replacement, Remove the top board: 21 단계, 이미지 3개 중 3개
    • Be careful not to puncture or deform the battery during this step.
    • Insert the flat end of a spudger under the bottom edge of the top board.
    • Twist the spudger to lift the top board and unclip it from the frame.
    • Remove the top board.
  22. Google Pixel 9 Pro Fold Outer Front Camera Replacement, Remove the outer front camera: 22 단계, 이미지 3개 중 1개 Google Pixel 9 Pro Fold Outer Front Camera Replacement, Remove the outer front camera: 22 단계, 이미지 3개 중 2개 Google Pixel 9 Pro Fold Outer Front Camera Replacement, Remove the outer front camera: 22 단계, 이미지 3개 중 3개
    • Don't press down heavily on the top board during this step to prevent bending the metal springs and connector pins.
    • Insert the point of a spudger under the top right corner of the front camera press connector, next to the golden marker on the top board.
    • Don't insert your spudger anywhere else, as you risk dislodging surface‑mounted components.
    • Pry up and disconnect the outer front camera.
  23. Google Pixel 9 Pro Fold Outer Front Camera Replacement, End of disassembly: 23 단계, 이미지 1개 중 1개
    • Congratulations on completing disassembly! The remaining steps will show you how to reassemble your device.
  24. Google Pixel 9 Pro Fold Outer Front Camera Replacement, Reconnect the outer front camera: 24 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Outer Front Camera Replacement, Reconnect the outer front camera: 24 단계, 이미지 2개 중 2개
    • Use your fingers to pinch the outer front camera press connector into its socket on the top board to reconnect it.
  25. Google Pixel 9 Pro Fold Outer Front Camera Replacement, Reinstall the top board: 25 단계, 이미지 3개 중 1개 Google Pixel 9 Pro Fold Outer Front Camera Replacement, Reinstall the top board: 25 단계, 이미지 3개 중 2개 Google Pixel 9 Pro Fold Outer Front Camera Replacement, Reinstall the top board: 25 단계, 이미지 3개 중 3개
    • Press the top edge of the top board against the frame at a downward angle to engage its metal spring.
    • Press the board flat to the frame, making sure the screw holes are aligned.
  26. Google Pixel 9 Pro Fold Outer Front Camera Replacement: 26 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Outer Front Camera Replacement: 26 단계, 이미지 2개 중 2개
    • Use a Torx Plus 3IP driver to install the 2.2 mm‑long screw securing the top board.
  27. Google Pixel 9 Pro Fold Outer Front Camera Replacement, Reconnect the top interconnect cable: 27 단계, 이미지 1개 중 1개
    • Reconnect the top interconnect cable press connector.
  28. Google Pixel 9 Pro Fold Outer Front Camera Replacement, Reinstall the top interconnect cable bracket: 28 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Outer Front Camera Replacement, Reinstall the top interconnect cable bracket: 28 단계, 이미지 2개 중 2개
    • Place the top interconnect cable bracket on the top board and align its screw holes.
  29. Google Pixel 9 Pro Fold Outer Front Camera Replacement: 29 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Outer Front Camera Replacement: 29 단계, 이미지 2개 중 2개
    • Use a Torx Plus 3IP driver to install the two 2.2 mm‑long screws securing the top interconnect cable bracket.
  30. Google Pixel 9 Pro Fold Outer Front Camera Replacement, Reinstall the rubber block: 30 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Outer Front Camera Replacement, Reinstall the rubber block: 30 단계, 이미지 2개 중 2개
    • Place the rubber block over its spot on the top board and press it down.
  31. Google Pixel 9 Pro Fold Outer Front Camera Replacement, Reconnect the flip battery: 31 단계, 이미지 1개 중 1개
    • Reconnect the flip battery press connector.
  32. Google Pixel 9 Pro Fold Outer Front Camera Replacement, Reinstall the flip battery bracket: 32 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Outer Front Camera Replacement, Reinstall the flip battery bracket: 32 단계, 이미지 2개 중 2개
    • Lay the flip battery bracket over the press connector and align the screw holes.
  33. Google Pixel 9 Pro Fold Outer Front Camera Replacement: 33 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Outer Front Camera Replacement: 33 단계, 이미지 2개 중 2개
    • Use a Torx Plus 3IP driver to install the 2.0 mm‑long screw securing the battery bracket.
  34. Google Pixel 9 Pro Fold Outer Front Camera Replacement, Remove the old adhesive: 34 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Outer Front Camera Replacement, Remove the old adhesive: 34 단계, 이미지 2개 중 2개
    • If your outer screen adhesive at the bottom left corner isn't sticky anymore, follow the next four steps to replace it. Otherwise, skip the next four steps.
    • Use a spudger, or your fingers, to remove the old bottom left outer screen adhesive.
    • Use isopropyl alcohol (>90%) and a coffee filter or a microfiber cloth to remove any adhesive residue.
  35. Google Pixel 9 Pro Fold Outer Front Camera Replacement, Compare your new adhesive: 35 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Outer Front Camera Replacement, Compare your new adhesive: 35 단계, 이미지 2개 중 2개
    • Before removing any liners, check if the bottom left outer screen adhesive matches the frame.
    • The clear liner should face the frame.
  36. Google Pixel 9 Pro Fold Outer Front Camera Replacement, Apply the new adhesive: 36 단계, 이미지 3개 중 1개 Google Pixel 9 Pro Fold Outer Front Camera Replacement, Apply the new adhesive: 36 단계, 이미지 3개 중 2개 Google Pixel 9 Pro Fold Outer Front Camera Replacement, Apply the new adhesive: 36 단계, 이미지 3개 중 3개
    • Peel the bottom left outer screen adhesive off its clear liner to expose the adhesive.
    • Put the adhesive into place on the frame.
  37. Google Pixel 9 Pro Fold Outer Front Camera Replacement: 37 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Outer Front Camera Replacement: 37 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger to press along the adhesive strip to adhere it to the frame.
  38. Google Pixel 9 Pro Fold Outer Front Camera Replacement, Apply the new adhesive: 38 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Outer Front Camera Replacement, Apply the new adhesive: 38 단계, 이미지 2개 중 2개
    • Before removing any liners, check if the perimeter outer screen adhesive matches the frame.
  39. Google Pixel 9 Pro Fold Outer Front Camera Replacement: 39 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Outer Front Camera Replacement: 39 단계, 이미지 2개 중 2개
    • Be careful during this step, as it's easy to stick the adhesive in the wrong spot. Take your time and work slowly.
    • Peel away the top half of the new adhesive strip from its clear liner and keep it folded.
  40. Google Pixel 9 Pro Fold Outer Front Camera Replacement: 40 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Outer Front Camera Replacement: 40 단계, 이미지 2개 중 2개
    • Align the top half of the adhesive over the frame, using the corners as reference points.
    • Place the adhesive on the frame.
  41. Google Pixel 9 Pro Fold Outer Front Camera Replacement: 41 단계, 이미지 3개 중 1개 Google Pixel 9 Pro Fold Outer Front Camera Replacement: 41 단계, 이미지 3개 중 2개 Google Pixel 9 Pro Fold Outer Front Camera Replacement: 41 단계, 이미지 3개 중 3개
    • Use the flat end of a spudger, or your fingers, to press down the top edge of the adhesive and adhere it to the frame.
  42. Google Pixel 9 Pro Fold Outer Front Camera Replacement: 42 단계, 이미지 3개 중 1개 Google Pixel 9 Pro Fold Outer Front Camera Replacement: 42 단계, 이미지 3개 중 2개 Google Pixel 9 Pro Fold Outer Front Camera Replacement: 42 단계, 이미지 3개 중 3개
    • While peeling away the rest of the clear liner, slowly lay the rest of the adhesive over the perimeter of the phone.
  43. Google Pixel 9 Pro Fold Outer Front Camera Replacement: 43 단계, 이미지 3개 중 1개 Google Pixel 9 Pro Fold Outer Front Camera Replacement: 43 단계, 이미지 3개 중 2개 Google Pixel 9 Pro Fold Outer Front Camera Replacement: 43 단계, 이미지 3개 중 3개
    • Use the flat end of a spudger, or your fingers, to press down the rest of the adhesive and adhere it to the frame.
  44. Google Pixel 9 Pro Fold Outer Front Camera Replacement: 44 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Outer Front Camera Replacement: 44 단계, 이미지 2개 중 2개
    • Use the tip of a spudger to pry up the segmented tab on the bottom left corner of the large blue liner.
  45. Google Pixel 9 Pro Fold Outer Front Camera Replacement: 45 단계, 이미지 3개 중 1개 Google Pixel 9 Pro Fold Outer Front Camera Replacement: 45 단계, 이미지 3개 중 2개 Google Pixel 9 Pro Fold Outer Front Camera Replacement: 45 단계, 이미지 3개 중 3개
    • Lift the tab and peel off the large blue liner to expose the secondary liner.
    • If any of the adhesive starts to peel up with the liner, gently lay it back on the frame and use the flat end of a spudger to secure it to the frame.
  46. Google Pixel 9 Pro Fold Outer Front Camera Replacement, Reconnect the outer screen: 46 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Outer Front Camera Replacement, Reconnect the outer screen: 46 단계, 이미지 2개 중 2개
    • Support the screen with your hand or prop it up on something sturdy.
    • Reconnect the outer screen cable press connector.
  47. Google Pixel 9 Pro Fold Outer Front Camera Replacement, Reinstall the outer screen cable bracket: 47 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Outer Front Camera Replacement, Reinstall the outer screen cable bracket: 47 단계, 이미지 2개 중 2개
    • Reinsert the outer screen cable bracket clip under the frame and align its screw hole.
  48. Google Pixel 9 Pro Fold Outer Front Camera Replacement: 48 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Outer Front Camera Replacement: 48 단계, 이미지 2개 중 2개
    • Use a Torx Plus 3IP driver to install the 2.2 mm‑long screw securing the display cable bracket.
  49. Google Pixel 9 Pro Fold Outer Front Camera Replacement, Expose the adhesive: 49 단계, 이미지 3개 중 1개 Google Pixel 9 Pro Fold Outer Front Camera Replacement, Expose the adhesive: 49 단계, 이미지 3개 중 2개 Google Pixel 9 Pro Fold Outer Front Camera Replacement, Expose the adhesive: 49 단계, 이미지 3개 중 3개
    • Remove the blue liner from the bottom left outer screen adhesive strip.
    • While holding the screen above the frame, separate one of the secondary liner's pull tabs at the bottom left corner.
  50. Google Pixel 9 Pro Fold Outer Front Camera Replacement: 50 단계, 이미지 3개 중 1개 Google Pixel 9 Pro Fold Outer Front Camera Replacement: 50 단계, 이미지 3개 중 2개 Google Pixel 9 Pro Fold Outer Front Camera Replacement: 50 단계, 이미지 3개 중 3개
    • Still holding the screen, peel off the secondary liner to expose the adhesive.
  51. Google Pixel 9 Pro Fold Outer Front Camera Replacement, Secure the outer screen: 51 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Outer Front Camera Replacement, Secure the outer screen: 51 단계, 이미지 2개 중 2개
    • Align the outer screen over the frame and press it into place.
  52. Google Pixel 9 Pro Fold Outer Front Camera Replacement: 52 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Outer Front Camera Replacement: 52 단계, 이미지 2개 중 2개
    • Press along the perimeter of the outer screen to adhere it to the frame.
    • Optionally, you can use a hair dryer or heat gun to lightly heat the edges of the back cover and create a stronger bond.
    • Let the phone sit a few hours for the adhesive to cure.
결론
Congratulations on completing your repair!
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Google Pixel 9 Pro Fold Answers Community for help.
작성자
1다른 기여자 명과 함께
Alex Diaz-Kokaisl
회원 가입일: 01/16/22
212,626 평판
안내서 1,039개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,608개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 23
전체 시간: 246
