주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Google Pixel 9 Pro XL Rear Cover Replacement
필요한 것
  1. Google Pixel 9 Pro XL Rear Cover Replacement, Safety precautions: 1 단계, 이미지 2개 중 1개 Google Pixel 9 Pro XL Rear Cover Replacement, Safety precautions: 1 단계, 이미지 2개 중 2개
    • Let your Pixel's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables and completely power down your phone.
  2. Google Pixel 9 Pro XL Rear Cover Replacement, Adhesive information: 2 단계, 이미지 3개 중 1개 Google Pixel 9 Pro XL Rear Cover Replacement, Adhesive information: 2 단계, 이미지 3개 중 2개 Google Pixel 9 Pro XL Rear Cover Replacement, Adhesive information: 2 단계, 이미지 3개 중 3개
    • Adhesive secures the perimeter of the rear cover to the frame.
    • When separating the adhesive, don't insert your tool more than 3 mm under the rear cover to avoid damaging the internal components.
    • Measure 3 mm from the tip and mark your opening pick with a permanent marker. Alternatively, you can tape a coin to a pick 3 mm from the tip.
  3. Google Pixel 9 Pro XL Rear Cover Replacement, Apply a suction handle: 3 단계, 이미지 2개 중 1개 Google Pixel 9 Pro XL Rear Cover Replacement, Apply a suction handle: 3 단계, 이미지 2개 중 2개
    • Attach a suction handle to the bottom edge of the rear cover, as close to the edge as possible.
  4. Google Pixel 9 Pro XL Rear Cover Replacement, Insert an opening pick: 4 단계, 이미지 3개 중 1개 Google Pixel 9 Pro XL Rear Cover Replacement, Insert an opening pick: 4 단계, 이미지 3개 중 2개 Google Pixel 9 Pro XL Rear Cover Replacement, Insert an opening pick: 4 단계, 이미지 3개 중 3개
    • Pull up on the suction handle with strong, steady force to create a small gap under the rear cover.
    • Insert the tip of an opening pick in the gap.
  5. Google Pixel 9 Pro XL Rear Cover Replacement, Separate the rear cover adhesive: 5 단계, 이미지 3개 중 1개 Google Pixel 9 Pro XL Rear Cover Replacement, Separate the rear cover adhesive: 5 단계, 이미지 3개 중 2개 Google Pixel 9 Pro XL Rear Cover Replacement, Separate the rear cover adhesive: 5 단계, 이미지 3개 중 3개
    • Slide your opening pick along the bottom edge to separate the adhesive securing it.
    • Remember: don't insert the opening pick deeper than 3 mm.
  6. Google Pixel 9 Pro XL Rear Cover Replacement: 6 단계, 이미지 3개 중 1개 Google Pixel 9 Pro XL Rear Cover Replacement: 6 단계, 이미지 3개 중 2개 Google Pixel 9 Pro XL Rear Cover Replacement: 6 단계, 이미지 3개 중 3개
    • Slide your opening pick up the left edge and along the top edge to separate the adhesive.
  7. Google Pixel 9 Pro XL Rear Cover Replacement: 7 단계, 이미지 3개 중 1개 Google Pixel 9 Pro XL Rear Cover Replacement: 7 단계, 이미지 3개 중 2개 Google Pixel 9 Pro XL Rear Cover Replacement: 7 단계, 이미지 3개 중 3개
    • Slide your pick down the right edge to separate the remaining adhesive.
  8. Google Pixel 9 Pro XL Rear Cover Replacement, Prop up the rear cover: 8 단계, 이미지 3개 중 1개 Google Pixel 9 Pro XL Rear Cover Replacement, Prop up the rear cover: 8 단계, 이미지 3개 중 2개 Google Pixel 9 Pro XL Rear Cover Replacement, Prop up the rear cover: 8 단계, 이미지 3개 중 3개
    • Don't try to fully remove the rear cover yet, as a ribbon cable on the right edge connects it to the phone.
    • Use the suction handle to lift the left edge of the rear cover and swing it over the right edge, like opening the cover of a book.
    • If you're having trouble, check the perimeter for any remaining adhesive and use your opening pick to separate it.
    • Prop up the rear cover with the suction handle so you can access the ribbon cable near the top right corner.
  9. Google Pixel 9 Pro XL Rear Cover Replacement, Remove the cable cover: 9 단계, 이미지 2개 중 1개 Google Pixel 9 Pro XL Rear Cover Replacement, Remove the cable cover: 9 단계, 이미지 2개 중 2개
    • Use a Torx Plus 3IP screwdriver to remove the two 5.2 mm‑long screws securing the cable cover.
  10. Google Pixel 9 Pro XL Rear Cover Replacement: 10 단계, 이미지 2개 중 1개 Google Pixel 9 Pro XL Rear Cover Replacement: 10 단계, 이미지 2개 중 2개
    • Use tweezers or your fingers to remove the cable cover.
  11. Google Pixel 9 Pro XL Rear Cover Replacement, Disconnect the rear cover: 11 단계, 이미지 3개 중 1개 Google Pixel 9 Pro XL Rear Cover Replacement, Disconnect the rear cover: 11 단계, 이미지 3개 중 2개 Google Pixel 9 Pro XL Rear Cover Replacement, Disconnect the rear cover: 11 단계, 이미지 3개 중 3개
    • Use the point of a spudger to pry up and disconnect the rear cover press connector.
  12. Google Pixel 9 Pro XL Rear Cover Replacement, Remove the rear cover: 12 단계, 이미지 1개 중 1개
    • Remove the rear cover.
    • During reassembly, follow this guide to apply new adhesive and install your back cover.
결론
To reassemble your device, follow this guide.
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
다른 8명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Spencer Day
회원 가입일: 09/14/22
177,897 평판
안내서 1,142개를 작성함
iFixit iFixit 회원
Staff
124 회원들
안내서 25,074개를 작성함
5가이드 댓글
User Torx Plus 3IP screwdriver? I don't find the screwdriver anywhere . Can I use one screw from this toolkit? If so, which one? - Essential Electronics Toolkit
Ram A - 답글 공유
Hi Ram. The Torx Plus 3IP bit (not driver) and many other bits are available here on our site. We also have drivers, in both aluminum and plastic.
Spencer Day - 공유
Does the rear cover come with glue? Or I have to buy the separately?
Bruno Llangostera Prats - 답글 공유
ifixit's instructions that show a suction cup to remove a screen or a glass back always assume your glass is intact. I would assume most often it is shattered so forget using a suction cup. I used some thick shipping tape to cover the broken glass which gives the suction cup a chance to hold.
Scott Z - 답글 공유
Easy guide to follow. I was able to replace my back glass due to the camera bar separating from the glass. Thank you!
David Z - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 11
지난 7일: 81
지난 30일: 415
전체 시간: 6,889
