주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Google Pixel C Headphone Jack Replacement
필요한 것
  1. Google Pixel C Headphone Jack Replacement, Screen: 1 단계, 이미지 1개 중 1개
    • Ensure that the device is completely powered down before beginning to take it apart
    • Use a heat gun to melt the adhesive that holds the screen to the device
    • Move the heat gun around the edge of the screen for approximately 1 minute, or until the screen can be lifted off in the next step.
    • Make sure not to heat the screen for too long because too much can damage other components inside the tablet.
  2. Google Pixel C Headphone Jack Replacement: 2 단계, 이미지 2개 중 1개 Google Pixel C Headphone Jack Replacement: 2 단계, 이미지 2개 중 2개
    • Use a suction cup to assist in lifting the screen while prying around its edges with a plastic spudger.
    • If necessary use a metal spudger to pry the screen up, taking care not to scratch the device.
    • Be careful not to pull the screen too far off. It will still be attached to the device by a cable for the front facing camera and the wide display data cable.
    • Reattaching the screen will require adhesive to ensure that it stays in place.
  3. Google Pixel C Headphone Jack Replacement: 3 단계, 이미지 2개 중 1개 Google Pixel C Headphone Jack Replacement: 3 단계, 이미지 2개 중 2개
    • Detach the cables for the camera by lifting the small flap using the tip of your fingernail or a spudger. Gently pull the ribbon cable out.
  4. Google Pixel C Headphone Jack Replacement: 4 단계, 이미지 2개 중 1개 Google Pixel C Headphone Jack Replacement: 4 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Follow the same removal procedure to detach the wide gold cable.
    • When reattaching cables, it is helpful to use tweezers to slide the cable in before securing it down with the flap.
    • This device is missing a battery, so the device that you are working on may appear slightly different inside.
  5. Google Pixel C Headphone Jack Replacement, Headphone Jack: 5 단계, 이미지 1개 중 1개
    • Orient the device so that the headphone jack is in the bottom right corner.
  6. Google Pixel C Headphone Jack Replacement: 6 단계, 이미지 2개 중 1개 Google Pixel C Headphone Jack Replacement: 6 단계, 이미지 2개 중 2개
    • Remove the two 3.5mm Phillips #000 screws.
  7. Google Pixel C Headphone Jack Replacement: 7 단계, 이미지 1개 중 1개
    • Locate and remove the two 2.5mm Phillips #000 screws on either side of the wire coil.
  8. Google Pixel C Headphone Jack Replacement: 8 단계, 이미지 2개 중 1개 Google Pixel C Headphone Jack Replacement: 8 단계, 이미지 2개 중 2개
    • Detach the red and black cable using a narrow spudger.
  9. Google Pixel C Headphone Jack Replacement: 9 단계, 이미지 2개 중 1개 Google Pixel C Headphone Jack Replacement: 9 단계, 이미지 2개 중 2개
    • Detach the cable connecting to the headphone jack.
  10. Google Pixel C Headphone Jack Replacement: 10 단계, 이미지 2개 중 1개 Google Pixel C Headphone Jack Replacement: 10 단계, 이미지 2개 중 2개
    • Lift the headphone jack, coiled wire, and cable, peeling the adhesive back.
    • Reassembly will require adhesive to ensure that the components are secured to the device.
결론
작성자
1다른 기여자 명과 함께
Deborah Iwakiri
회원 가입일: 04/25/17
522 평판
안내서 2개를 작성함
Cal Poly, Team S21-G4, Livingston Spring 2017 Cal Poly, Team S21-G4, Livingston Spring 2017 회원
CPSU-LIVINGSTON-S17S21G4
4 회원들
안내서 11개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 67
전체 시간: 1,297
