주요 콘텐츠로 건너뛰기
Google Pixel C Screen Replacement
필요한 것
  1. Google Pixel C Screen Replacement, Screen: 1 단계, 이미지 1/1
    • Ensure that the device is completely powered down before beginning to take it apart
    • Use a heat gun to melt the adhesive that holds the screen to the device
    • Move the heat gun around the edge of the screen for approximately 1 minute, or until the screen can be lifted off in the next step.
    • Make sure not to heat the screen for too long because too much can damage other components inside the tablet.
  2. Google Pixel C Screen Replacement: 2 단계, 이미지 1/2 Google Pixel C Screen Replacement: 2 단계, 이미지 2/2
    • Use a suction cup to assist in lifting the screen while prying around its edges with a plastic spudger.
    • If necessary use a metal spudger to pry the screen up, taking care not to scratch the device.
    • Be careful not to pull the screen too far off. It will still be attached to the device by a cable for the front facing camera and the wide display data cable.
    • Reattaching the screen will require adhesive to ensure that it stays in place.
  3. Google Pixel C Screen Replacement: 3 단계, 이미지 1/2 Google Pixel C Screen Replacement: 3 단계, 이미지 2/2
    • Detach the cables for the camera by lifting the small flap using the tip of your fingernail or a spudger. Gently pull the ribbon cable out.
  4. Google Pixel C Screen Replacement: 4 단계, 이미지 1/2 Google Pixel C Screen Replacement: 4 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Follow the same removal procedure to detach the wide gold cable.
    • When reattaching cables, it is helpful to use tweezers to slide the cable in before securing it down with the flap.
    • This device is missing a battery, so the device that you are working on may appear slightly different inside.
결론
다른 9명이 해당 안내서를 완성하였습니다.
Deborah Iwakiri
회원 가입일: 04/25/17
522 평판
안내서 2개 작성하였습니다
Cal Poly, Team S21-G4, Livingston Spring 2017 Cal Poly, Team S21-G4, Livingston Spring 2017 회원
CPSU-LIVINGSTON-S17S21G4
4 회원들
안내서 11개 작성하였습니다
댓글 28개
Where can a replacement screen be located?
Ronnie Williams - 답글
Where can i buy a spare screen for this tablet?
Luigi Abbinante - 답글
Yes, I have to buy the screen too, but where??
Кирилл Кнышев - 답글
All very nice but unfortunately useless without knowing where to get the parts :(
Lorenzo Braschi - 답글
Ciao Lorenzo, sei poi riuscito a trovare il ricambio?
Luigi Abbinante -
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 10
30일 전: 139
전체 시간: 17,738
