이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
If the device does not recognize fingers correctly, replacing the fingerprint scanner may solve this issue. Use this guide to replace a broken Pixel fingerprint scanner.
필요한 것
Turn off the device.
Prepare an iOpener to heat the edges of the display and soften the adhesive underneath. Alternatively, you may use a heat gun or a hair dryer.
이 단계에 사용된 도구:Suction Handle$2.99
Use a suction handle to pull up on the display and create a slight gap between the display and the phone's chassis.
You may need to apply more heat if this doesn't come up. Don't be impatient, this will take time. Once you can gently insert a tool in the gap, move on to the next step.
Use a SIM ejection tool to remove the SIM card tray located at the top left of the device.
Use a spudger to pry up the black and white coaxial cables attached to the upper right and left-hand sides of the motherboard.
다른 5명이 해당 안내서를 완성하였습니다.
댓글 한 개
Do I need fresh adhesivd when reattaching the screen? Can I just heat up the old adhesive in-place and re-use it? Incomplete guide.
