주요 콘텐츠로 건너뛰기
Google Pixel Slate Front-Facing Camera Replacement
필요한 것
  1. Google Pixel Slate Front-Facing Camera Replacement, Screen: 1 단계, 이미지 1/3 Google Pixel Slate Front-Facing Camera Replacement, Screen: 1 단계, 이미지 2/3 Google Pixel Slate Front-Facing Camera Replacement, Screen: 1 단계, 이미지 3/3
    • Orient the Google Pixel Slate so that the screen is facing upwards.
    • Use the iFixit opening tool to separate screen from main body.
    • Use the suction cup to remove the screen from the body of the device.
  2. Google Pixel Slate Front-Facing Camera Replacement: 2 단계, 이미지 1/3 Google Pixel Slate Front-Facing Camera Replacement: 2 단계, 이미지 2/3 Google Pixel Slate Front-Facing Camera Replacement: 2 단계, 이미지 3/3
    • Gently disconnect the three flat-wires from the screen.
    • Carefully separate and remove the screen from the body of the device.
  3. Google Pixel Slate Front-Facing Camera Replacement, Front-Facing Camera: 3 단계, 이미지 1/3 Google Pixel Slate Front-Facing Camera Replacement, Front-Facing Camera: 3 단계, 이미지 2/3 Google Pixel Slate Front-Facing Camera Replacement, Front-Facing Camera: 3 단계, 이미지 3/3
    • Once removed, place the screen face down.
    • Peel back the black, adhesive strip covering the front camera so that the silver plate is exposed.
  4. Google Pixel Slate Front-Facing Camera Replacement: 4 단계, 이미지 1/3 Google Pixel Slate Front-Facing Camera Replacement: 4 단계, 이미지 2/3 Google Pixel Slate Front-Facing Camera Replacement: 4 단계, 이미지 3/3
    • Hold back the adhesive tape to expose the two black 2mm screws that are holding down the cover plate.
    • Use the T2 Torx screwdriver to remove the two 2mm screws.
  5. Google Pixel Slate Front-Facing Camera Replacement: 5 단계, 이미지 1/2 Google Pixel Slate Front-Facing Camera Replacement: 5 단계, 이미지 2/2
    • Once the two 2mm screws are removed, lift and remove the cover plate.
  6. Google Pixel Slate Front-Facing Camera Replacement: 6 단계, 이미지 1/2 Google Pixel Slate Front-Facing Camera Replacement: 6 단계, 이미지 2/2
    • Pull upwards on the flat wire to remove the front-facing camera from the device.
    • The camera may be secured to the screen body with adhesive tape. Apply gentle force to remove the camera by removing the tape.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Spencer Alonge
회원 가입일: 04/18/19
648 평판
안내서 5개 작성하였습니다
Cal Poly, Team S2-G5, Maness Spring 2019 Cal Poly, Team S2-G5, Maness Spring 2019 회원
CPSU-MANESS-S19S2G5
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 10
전체 시간: 796
