주요 콘텐츠로 건너뛰기
Google Pixel Slate Motherboard Replacement
필요한 것
  1. Google Pixel Slate Motherboard Replacement, Screen: 1 단계, 이미지 1/3 Google Pixel Slate Motherboard Replacement, Screen: 1 단계, 이미지 2/3 Google Pixel Slate Motherboard Replacement, Screen: 1 단계, 이미지 3/3
    • Orient the Google Pixel Slate so that the screen is facing upwards.
    • Use the iFixit opening tool to separate screen from main body.
    • Use the suction cup to remove the screen from the body of the device.
  2. Google Pixel Slate Motherboard Replacement: 2 단계, 이미지 1/3 Google Pixel Slate Motherboard Replacement: 2 단계, 이미지 2/3 Google Pixel Slate Motherboard Replacement: 2 단계, 이미지 3/3
    • Gently disconnect the three flat-wires from the screen.
    • Carefully separate and remove the screen from the body of the device.
  3. Google Pixel Slate Motherboard Replacement, Motherboard: 3 단계, 이미지 1/3 Google Pixel Slate Motherboard Replacement, Motherboard: 3 단계, 이미지 2/3 Google Pixel Slate Motherboard Replacement, Motherboard: 3 단계, 이미지 3/3
    • Once the screen is removed, remove the two black, adhesive strips.
  4. Google Pixel Slate Motherboard Replacement: 4 단계, 이미지 1/3 Google Pixel Slate Motherboard Replacement: 4 단계, 이미지 2/3 Google Pixel Slate Motherboard Replacement: 4 단계, 이미지 3/3
    • Use a T3 Torx screwdriver to remove the two black screws that are holding down the copper strip.
  5. Google Pixel Slate Motherboard Replacement: 5 단계, 이미지 1/3 Google Pixel Slate Motherboard Replacement: 5 단계, 이미지 2/3 Google Pixel Slate Motherboard Replacement: 5 단계, 이미지 3/3
    • Use the T3 Torx screwdriver to remove the seven 3mm screws.
    • Use a T2 Torx screwdriver to remove the pink 2mm screw closest to the edge.
    • There is a total of four blue 3mm screws, two black 3mm screws, one pink 3mm screw, and one pink 2mm screw holding down the plate.
  6. Google Pixel Slate Motherboard Replacement: 6 단계, 이미지 1/2 Google Pixel Slate Motherboard Replacement: 6 단계, 이미지 2/2
    • Lift and remove the metal plate.
  7. Google Pixel Slate Motherboard Replacement: 7 단계, 이미지 1/3 Google Pixel Slate Motherboard Replacement: 7 단계, 이미지 2/3 Google Pixel Slate Motherboard Replacement: 7 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Remove the two speaker plugs, one battery plug, and disconnect the four flat wires from the motherboard.
    • Nylon Tipped Tweezers may be necessary to remove the wires effectively.
  8. Google Pixel Slate Motherboard Replacement: 8 단계, 이미지 1/3 Google Pixel Slate Motherboard Replacement: 8 단계, 이미지 2/3 Google Pixel Slate Motherboard Replacement: 8 단계, 이미지 3/3
    • Use a T3 Torx screwdriver to remove the two silver screws.
    • Remove the 4 exposed washers from the motherboard and put aside.
  9. Google Pixel Slate Motherboard Replacement: 9 단계, 이미지 1/3 Google Pixel Slate Motherboard Replacement: 9 단계, 이미지 2/3 Google Pixel Slate Motherboard Replacement: 9 단계, 이미지 3/3
    • Use the iFixit opening tool to remove the motherboard from the device.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Spencer Alonge
회원 가입일: 04/18/19
648 평판
안내서 5개 작성하였습니다
Cal Poly, Team S2-G5, Maness Spring 2019 Cal Poly, Team S2-G5, Maness Spring 2019 회원
CPSU-MANESS-S19S2G5
4 회원들
안내서 5개 작성하였습니다
댓글 한 개
Very helpful, nice and clear steps.
Eddie Lundberg - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 13
30일 전: 64
전체 시간: 3,389
