주요 콘텐츠로 건너뛰기
Google Pixel Slate Screen Replacement
필요한 것
  1. Google Pixel Slate Screen Replacement, Screen: 1 단계, 이미지 3개 중 1개 Google Pixel Slate Screen Replacement, Screen: 1 단계, 이미지 3개 중 2개 Google Pixel Slate Screen Replacement, Screen: 1 단계, 이미지 3개 중 3개
    • Orient the Google Pixel Slate so that the screen is facing upwards.
    • Use the iFixit opening tool to separate screen from main body.
    • Use the suction cup to remove the screen from the body of the device.
  2. Google Pixel Slate Screen Replacement: 2 단계, 이미지 3개 중 1개 Google Pixel Slate Screen Replacement: 2 단계, 이미지 3개 중 2개 Google Pixel Slate Screen Replacement: 2 단계, 이미지 3개 중 3개
    • Gently disconnect the three flat-wires from the screen.
    • Carefully separate and remove the screen from the body of the device.
결론
다른 5명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Spencer Alonge
회원 가입일: 04/18/19
678 평판
안내서 5개를 작성함
Cal Poly, Team S2-G5, Maness Spring 2019 Cal Poly, Team S2-G5, Maness Spring 2019 회원
CPSU-MANESS-S19S2G5
4 회원들
안내서 5개를 작성함
13가이드 댓글
Where did you source the replacement screen? Can we get a link added to the parts list?
Brandon Price - 답글
Anyone know where to source the replacement screen? Any help would be greatly appreciated.
Brandon Price - 답글
Yeah, I could use the replacement source as well. Thanks.
Benjamin Reese - 답글
me too! the resource replacement link plz!!
gabriela urquidi - 답글
Is the screen held down with adhesive or does it have any clips? Also, does anyone know where I could source any Pixel Slate parts?
Kevin Freyre - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 11
지난 30일: 38
전체 시간: 5,521
