주요 콘텐츠로 건너뛰기
Google Pixel Slate Speaker Replacement
필요한 것
  1. Google Pixel Slate Speaker Replacement, Screen: 1 단계, 이미지 3개 중 1개 Google Pixel Slate Speaker Replacement, Screen: 1 단계, 이미지 3개 중 2개 Google Pixel Slate Speaker Replacement, Screen: 1 단계, 이미지 3개 중 3개
    • Orient the Google Pixel Slate so that the screen is facing upwards.
    • Use the iFixit opening tool to separate screen from main body.
    • Use the suction cup to remove the screen from the body of the device.
  2. Google Pixel Slate Speaker Replacement: 2 단계, 이미지 3개 중 1개 Google Pixel Slate Speaker Replacement: 2 단계, 이미지 3개 중 2개 Google Pixel Slate Speaker Replacement: 2 단계, 이미지 3개 중 3개
    • Gently disconnect the three flat-wires from the screen.
    • Carefully separate and remove the screen from the body of the device.
  3. Google Pixel Slate Speaker Replacement, Speaker: 3 단계, 이미지 3개 중 1개 Google Pixel Slate Speaker Replacement, Speaker: 3 단계, 이미지 3개 중 2개 Google Pixel Slate Speaker Replacement, Speaker: 3 단계, 이미지 3개 중 3개
    • There are two speakers, one on each side of the Google Pixel Slate. This guide works for either one.
    • Use the T2 Torx screwdriver to remove the yellow 2mm screw from the thin metal plate.
    • Use the T3 Torx screwdriver to remove the pink 3mm screw from the thin metal plate.
    • Remove the thin metal plate from the device.
  4. Google Pixel Slate Speaker Replacement: 4 단계, 이미지 1개 중 1개
    • Use the T2 Torx screwdriver to remove the two black 2mm screws from the speaker.
  5. Google Pixel Slate Speaker Replacement: 5 단계, 이미지 2개 중 1개 Google Pixel Slate Speaker Replacement: 5 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use the Nylon-Tipped Tweezers to remove the black plug.
    • There is a red and a black wire connected to the black plug.
    • Pull the black plug in an upwards direction.
    • Be sure to gently remove plug, as using too much force can damage the connecting wires.
  6. Google Pixel Slate Speaker Replacement: 6 단계, 이미지 2개 중 1개 Google Pixel Slate Speaker Replacement: 6 단계, 이미지 2개 중 2개
    • Use the Nylon-Tipped Tweezers to disconnect the black tape-like plug connected to the speaker.
  7. Google Pixel Slate Speaker Replacement: 7 단계, 이미지 2개 중 1개 Google Pixel Slate Speaker Replacement: 7 단계, 이미지 2개 중 2개
    • Detach the speaker wire from the motherboard.
    • Remove the adhesive strips that hold down the speaker wire.
  8. Google Pixel Slate Speaker Replacement: 8 단계, 이미지 3개 중 1개 Google Pixel Slate Speaker Replacement: 8 단계, 이미지 3개 중 2개 Google Pixel Slate Speaker Replacement: 8 단계, 이미지 3개 중 3개
    • Use the T2 Torx screwdriver to remove the 2mm black screw from the brass plate.
    • Pull back the brass plate.
  9. Google Pixel Slate Speaker Replacement: 9 단계, 이미지 1개 중 1개
    • You can now remove the speaker from the device.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Spencer Alonge
회원 가입일: 04/18/19
663 평판
안내서 5개를 작성함
Cal Poly, Team S2-G5, Maness Spring 2019 Cal Poly, Team S2-G5, Maness Spring 2019 회원
CPSU-MANESS-S19S2G5
4 회원들
안내서 5개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 3
지난 30일: 12
전체 시간: 970
