주요 콘텐츠로 건너뛰기
Google Pixel XL Daughterboard Replacement
필요한 것
  1. Google Pixel XL Daughterboard Replacement, Display Assembly: 1 단계, 이미지 1/3 Google Pixel XL Daughterboard Replacement, Display Assembly: 1 단계, 이미지 2/3 Google Pixel XL Daughterboard Replacement, Display Assembly: 1 단계, 이미지 3/3
    • Heat an iOpener and apply it to the top edge of the display for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
    • Take note of the following regions before you begin prying:
    • Thin adhesive lined against the display panel
    • Thick adhesive
    • The OLED display panel, which is very prone to damage
    • The display cable, which can be damaged during prying
  2. Google Pixel XL Daughterboard Replacement: 2 단계, 이미지 1/3 Google Pixel XL Daughterboard Replacement: 2 단계, 이미지 2/3 Google Pixel XL Daughterboard Replacement: 2 단계, 이미지 3/3
    • Once the edge is warm to the touch, apply a suction cup close to the edge.
    • Lift on the suction cup, and insert an opening pick into the gap.
    • Do not insert the pick more than 13 mm (0.5 inches), or you will damage the display assembly.
    • If you have trouble creating a gap, reheat the edge and try again.
    • You can also try to use a playing card instead of an opening pick to help make the initial entry.
  3. Google Pixel XL Daughterboard Replacement: 3 단계, 이미지 1/3 Google Pixel XL Daughterboard Replacement: 3 단계, 이미지 2/3 Google Pixel XL Daughterboard Replacement: 3 단계, 이미지 3/3
    • Slide the opening clip across the top edge to slice through the adhesive.
    • Be sure not to cut deeper than 13 mm (0.5 inches) or you will damage the display.
    • There's a mesh covering the earpiece speaker on the top edge of the screen. If you don’t have a replacement mesh, take care not to damage or lose this component.
    • Leave an opening pick in the edge to prevent the adhesive from resealing.
  4. Google Pixel XL Daughterboard Replacement: 4 단계, 이미지 1/3 Google Pixel XL Daughterboard Replacement: 4 단계, 이미지 2/3 Google Pixel XL Daughterboard Replacement: 4 단계, 이미지 3/3
    • Heat an iOpener and apply it to the right edge of the phone for two minutes.
    • Insert an opening pick near the top edge of the phone, where you have already sliced the adhesive.
    • Slowly guide the pick around the right corner.
    • Carefully slide the pick down the right edge of the phone to slice through the adhesive.
    • Do not insert the pick more than 1 mm (1/32") along the edge, or you will damage the display assembly.
    • Repeat the step for the left edge of the phone.
  5. Google Pixel XL Daughterboard Replacement: 5 단계, 이미지 1/2 Google Pixel XL Daughterboard Replacement: 5 단계, 이미지 2/2
    • Heat the bottom edge with an iOpener for two minutes.
    • Insert a pick near the right edge where you have already loosened the adhesive.
    • Carefully guide the pick around the corner.
    • Slide the pick along the bottom edge to slice through the adhesive.
    • Do not slice deeper than 8.5 mm (1/3") or you will damage the display cable.
  6. Google Pixel XL Daughterboard Replacement: 6 단계, 이미지 1/1
    • Once you have sliced around the perimeter of the phone, carefully lift the display assembly up slightly by the right corners.
    • Do not attempt to remove the display assembly. It is still attached by a flex cable.
    • Use an opening pick to slice through any remaining adhesive.
  7. Google Pixel XL Daughterboard Replacement: 7 단계, 이미지 1/3 Google Pixel XL Daughterboard Replacement: 7 단계, 이미지 2/3 Google Pixel XL Daughterboard Replacement: 7 단계, 이미지 3/3
    • Lift the display assembly from the top end and swing it around such that it rests upside down on the frame.
    • Be careful not to strain the flex cable when you swing the assembly around.
  8. Google Pixel XL Daughterboard Replacement: 8 단계, 이미지 1/2 Google Pixel XL Daughterboard Replacement: 8 단계, 이미지 2/2
    이 단계에 사용된 도구:
    Magnetic Project Mat
    $19.95
    구매
    • Remove the two 4 mm T5 screws securing the display cable bracket.
    • Remove the display cable bracket.
  9. Google Pixel XL Daughterboard Replacement: 9 단계, 이미지 1/2 Google Pixel XL Daughterboard Replacement: 9 단계, 이미지 2/2
    • Use the point of a spudger to pry up and disconnect the display cable from its connector.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  10. Google Pixel XL Daughterboard Replacement: 10 단계, 이미지 1/3 Google Pixel XL Daughterboard Replacement: 10 단계, 이미지 2/3 Google Pixel XL Daughterboard Replacement: 10 단계, 이미지 3/3
    • Remove the display assembly.
    • For comprehensive instructions on how to reinstall the Pixel XL display, follow this guide.
    • If your replacement display did not come with a speaker grille, use tweezers to gently peel the adhesive grille from your old display, and transfer it to the replacement.
    • Before installing a new display, be sure to remove all traces of adhesive from the frame. Use a spudger or an opening tool to scrape it off, and use high-concentration isopropyl alcohol to remove any residue.
    • If you are reinstalling the same display assembly, be sure to remove all adhesive residue from the panel and the frame before applying new adhesive.
    • Be sure to turn on your phone and test your repair before installing new adhesive and resealing the phone.
    • During the boot-up process after reassembly, the screen will go through a calibration sequence. Do not touch the screen during this process, as it could result in improper touch calibration and create touch issues.
  11. Google Pixel XL Daughterboard Replacement, Google Pixel XL Opening Procedure: 11 단계, 이미지 1/1
    • Remove the following screws that secure the midframe to the back:
    • Seven black 4 mm T5 screws
    • Two silver 3 mm T5 screws
  12. Google Pixel XL Daughterboard Replacement: 12 단계, 이미지 1/1
    • The midframe is held tightly in place by plastic clips which push into the edge of the back case.
  13. Google Pixel XL Daughterboard Replacement: 13 단계, 이미지 1/3 Google Pixel XL Daughterboard Replacement: 13 단계, 이미지 2/3 Google Pixel XL Daughterboard Replacement: 13 단계, 이미지 3/3
    • Find the small notch in the bottom left corner of the frame and insert an opening pick.
    • Slide the opening pick along the bottom edge of the phone towards the bottom right corner and leave it there.
  14. Google Pixel XL Daughterboard Replacement: 14 단계, 이미지 1/3 Google Pixel XL Daughterboard Replacement: 14 단계, 이미지 2/3 Google Pixel XL Daughterboard Replacement: 14 단계, 이미지 3/3
    • Insert a separate opening pick into the right edge of the phone, near the bottom.
    • Slowly push the pick upwards along the seam until the first clip pops free.
    • Due to the tight tolerances, this may be difficult, requiring a substantial amount of force. If you are having trouble, try inserting and sliding a playing card.
    • Once you've released the clip, leave the opening pick in place to prevent the midframe from resealing.
  15. Google Pixel XL Daughterboard Replacement: 15 단계, 이미지 1/2 Google Pixel XL Daughterboard Replacement: 15 단계, 이미지 2/2
    • Insert an opening pick into the right edge of the phone and slide it upwards towards the top right clip.
    • You do not need to insert the pick more than 2 mm into the edge. If you insert the pick all the way in, you may risk damaging flex cables.
    • Slowly slide the pick past the clip to disengage it from the frame.
    • At this point, the right edge of the midframe should be free from the case. If it isn't, slide an opening clip up and down along the right edge.
  16. Google Pixel XL Daughterboard Replacement: 16 단계, 이미지 1/3 Google Pixel XL Daughterboard Replacement: 16 단계, 이미지 2/3 Google Pixel XL Daughterboard Replacement: 16 단계, 이미지 3/3
    • Grasp the right edge of the midframe by the corners and slowly hinge the edge up.
    • When the left edge feels loose, stop hinging and lift the midframe upwards.
    • Remove the midframe.
    • To reinstall the midframe, align it to the case, then squeeze around the perimeter until all the clips snap back into position. When properly done, the midframe should lie flat.
  17. Google Pixel XL Daughterboard Replacement, Charging Port: 17 단계, 이미지 1/3 Google Pixel XL Daughterboard Replacement, Charging Port: 17 단계, 이미지 2/3 Google Pixel XL Daughterboard Replacement, Charging Port: 17 단계, 이미지 3/3
    • Use the point of a spudger to pry up and disconnect the battery connector.
    • Bend the battery flex cable slightly so that it will not accidentally touch the motherboard.
  18. Google Pixel XL Daughterboard Replacement: 18 단계, 이미지 1/2 Google Pixel XL Daughterboard Replacement: 18 단계, 이미지 2/2
    • Use tweezers to peel up the tape at the top of the interconnect cable.
  19. Google Pixel XL Daughterboard Replacement: 19 단계, 이미지 1/2 Google Pixel XL Daughterboard Replacement: 19 단계, 이미지 2/2
    • Use the point of a spudger to pry up and disconnect the interconnect cable from the motherboard.
    • To reconnect during reinstallation, align the cable with the socket and use your finger to press down on one side, followed by the other. If done correctly, the cable should be firmly held in place by the socket.
  20. Google Pixel XL Daughterboard Replacement: 20 단계, 이미지 1/2 Google Pixel XL Daughterboard Replacement: 20 단계, 이미지 2/2
    • Use the point of a spudger to pry up and disconnect the interconnect cable from the bottom daughterboard.
    • Continue peeling the interconnect cable from the bottom daughterboard.
    • Remove the interconnect cable.
  21. Google Pixel XL Daughterboard Replacement: 21 단계, 이미지 1/2 Google Pixel XL Daughterboard Replacement: 21 단계, 이미지 2/2
  22. Google Pixel XL Daughterboard Replacement: 22 단계, 이미지 1/1
    • Remove the two 3 mm T5 screws securing the daughterboard to the frame.
  23. Google Pixel XL Daughterboard Replacement: 23 단계, 이미지 1/3 Google Pixel XL Daughterboard Replacement: 23 단계, 이미지 2/3 Google Pixel XL Daughterboard Replacement: 23 단계, 이미지 3/3
  24. Google Pixel XL Daughterboard Replacement: 24 단계, 이미지 1/3 Google Pixel XL Daughterboard Replacement: 24 단계, 이미지 2/3 Google Pixel XL Daughterboard Replacement: 24 단계, 이미지 3/3
    • Slowly lift the left edge of the daughterboard up, pulling the antenna patch off of the loudspeaker.
    • You can insert an opening pick under the antenna patch to help separate it from the loudspeaker.
    • If the antenna patch begins to rip, stop pulling. Heat an iOpener, apply it to the corner for a minute, and use an opening pick to help remove it from the loudspeaker.
  25. Google Pixel XL Daughterboard Replacement: 25 단계, 이미지 1/3 Google Pixel XL Daughterboard Replacement: 25 단계, 이미지 2/3 Google Pixel XL Daughterboard Replacement: 25 단계, 이미지 3/3
    • Flip the daughterboard over.
    • Use the point of a spudger to pry up and disconnect the black antenna cable from its socket.
    • Release the antenna cable from its retaining clip.
  26. Google Pixel XL Daughterboard Replacement: 26 단계, 이미지 1/3 Google Pixel XL Daughterboard Replacement: 26 단계, 이미지 2/3 Google Pixel XL Daughterboard Replacement: 26 단계, 이미지 3/3
    • Use the point of a spudger to pry up and disconnect the white antenna cable from its socket.
  27. Google Pixel XL Daughterboard Replacement: 27 단계, 이미지 1/3 Google Pixel XL Daughterboard Replacement: 27 단계, 이미지 2/3 Google Pixel XL Daughterboard Replacement: 27 단계, 이미지 3/3
    • If your replacement part does not come with a plastic barometric vent, transfer the one from your old part to the new one.
    • Use the edge of an opening tool to gently push up and loosen the barometric vent from the board.
    • Be careful not to push too hard, or you will bend the vent's plastic alignment pins.
    • You may need to use some adhesive or double-sided tape in order to attach the vent to the new part. If you do, be sure not to cover the bottom vent hole.
결론
Compare your new replacement part to the original part. You may need to transfer remaining components or remove adhesive backings from the new part before installing.
Repair didn’t go as planned? Check out our Google Pixel XL Answers community for troubleshooting help.
다른 17명이 해당 안내서를 완성하였습니다.
Arthur Shi
회원 가입일: 01/03/18
252,726 평판
안내서 526개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 16,817개 작성하였습니다
댓글 6개
Will this also work for the original Pixel as well, or is there a separate tear-down for it?
Thanks in advance.
Dieter
Dieter - 답글
There’s no reason to mess with the battery for this repair! Also, the screen breaks more easily than you think, so be super careful. I thought i was being careful and broke the screen.
Sherman Hartman - 답글
This guide has been updated!
Arthur Shi - 답글
When reattaching the screen, plug the screen in first, then the battery disconnect. if not, the screen won’t turn on.
Nathaniel MacDonald - 답글
I need to replace the charging board along with the ribbon cable that connects to the other part of the phone.. Any suggestions on where to purchase the ribbon cable?
Earl Grad - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 24
30일 전: 64
전체 시간: 12,153
