주요 콘텐츠로 건너뛰기
Google Pixel XL Opening Procedure
단지 전제 조건
이 안내서는 다른 가이드의 선행 작업으로 사용하기 위한 것입니다. 그 자체로는 불완전합니다.
필요한 것
  1. Google Pixel XL Opening Procedure, Google Pixel XL Opening Procedure: 1 단계, 이미지 1/1
    • Remove the following screws that secure the midframe to the back:
    • Seven black 4 mm T5 screws
    • Two silver 3 mm T5 screws
  2. Google Pixel XL Opening Procedure: 2 단계, 이미지 1/1
    • The midframe is held tightly in place by plastic clips which push into the edge of the back case.
  3. Google Pixel XL Opening Procedure: 3 단계, 이미지 1/3 Google Pixel XL Opening Procedure: 3 단계, 이미지 2/3 Google Pixel XL Opening Procedure: 3 단계, 이미지 3/3
    • Find the small notch in the bottom left corner of the frame and insert an opening pick.
    • Slide the opening pick along the bottom edge of the phone towards the bottom right corner and leave it there.
    This step was impossible on my phone as a gap could not be formed at the notch to pry the corner up using either pick or playing card . Flathead micro screwdriver was required causing insignificant cosmetic damage at that area.
    Darren Bass - 답글
    This step takes a few tries, starting with the pick perpendicular to the phone. Eventually, after gentle prying, it will catch the corner so you can slip the pick underneath. Like everything in this repair, it requires you to be exceedingly delicate and patient.
    Damian Matthews - 답글
    Take the tip of the tweezers, insert it in the screw hole near where they show to insert the pick and gently pry up. You should be able to move the plate upwards enough to insert the pick
    Michael hobbs - 답글
  4. Google Pixel XL Opening Procedure: 4 단계, 이미지 1/3 Google Pixel XL Opening Procedure: 4 단계, 이미지 2/3 Google Pixel XL Opening Procedure: 4 단계, 이미지 3/3
    • Insert a separate opening pick into the right edge of the phone, near the bottom.
    • Slowly push the pick upwards along the seam until the first clip pops free.
    • Due to the tight tolerances, this may be difficult, requiring a substantial amount of force. If you are having trouble, try inserting and sliding a playing card.
    • Once you've released the clip, leave the opening pick in place to prevent the midframe from resealing.
    I found that leaving the pick in the middle, and using it as a lever (think like bending a pipe over one’s knee and the pick in the middle is the knee) to “pop” the top edge up helped a lot more than trying to use more picks to pry this mid layer up…
    Jon T. - 답글
  5. Google Pixel XL Opening Procedure: 5 단계, 이미지 1/2 Google Pixel XL Opening Procedure: 5 단계, 이미지 2/2
    • Insert an opening pick into the right edge of the phone and slide it upwards towards the top right clip.
    • You do not need to insert the pick more than 2 mm into the edge. If you insert the pick all the way in, you may risk damaging flex cables.
    • Slowly slide the pick past the clip to disengage it from the frame.
    • At this point, the right edge of the midframe should be free from the case. If it isn't, slide an opening clip up and down along the right edge.
  6. Google Pixel XL Opening Procedure: 6 단계, 이미지 1/3 Google Pixel XL Opening Procedure: 6 단계, 이미지 2/3 Google Pixel XL Opening Procedure: 6 단계, 이미지 3/3
    • Grasp the right edge of the midframe by the corners and slowly hinge the edge up.
    • When the left edge feels loose, stop hinging and lift the midframe upwards.
    • Remove the midframe.
    • To reinstall the midframe, align it to the case, then squeeze around the perimeter until all the clips snap back into position. When properly done, the midframe should lie flat.
결론
Arthur Shi
회원 가입일: 01/03/18
249,673 평판
안내서 503개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 16,718개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 120
