주요 콘텐츠로 건너뛰기
Google Pixel XL Rear Facing Camera Replacement
보관된 가이드
해당 안내서는 단지 역사적인 목적으로 보관됩니다. 최신 버전 안내서를 사용하여 수리 하십시오.
필요한 것
  1. Google Pixel XL Rear Facing Camera Replacement, Rear Facing Camera: 1 단계, 이미지 1/1
    • Remove the two remaining 3mm T5 screws which secure the motherboard in place.
  2. Google Pixel XL Rear Facing Camera Replacement: 2 단계, 이미지 1/2 Google Pixel XL Rear Facing Camera Replacement: 2 단계, 이미지 2/2
    • Gently lift the motherboard slightly to access the connector which holds the motherboard from the bottom.
    • Disconnect the connector by pulling it away from the board.
  3. Google Pixel XL Rear Facing Camera Replacement: 3 단계, 이미지 1/1
    • Once the connector is removed, lift the motherboard out of the phone.
  4. Google Pixel XL Rear Facing Camera Replacement: 4 단계, 이미지 1/1
    • Orient the motherboard so that the large rear camera is on the top and facing upwards.
    • On the motherboard, remove the small blue board by prying it off with the plastic opening tool.
  5. Google Pixel XL Rear Facing Camera Replacement: 5 단계, 이미지 1/1
    • Using the plastic opening tool, undo the small connector which holds the camera in place.
    • Remove the camera from the board by gently lifting it off.
결론
Andrew Ferguson
회원 가입일: 03/14/17
1,395 평판
안내서 4개 작성하였습니다
Cal Poly, Team S13-G4, Forte Spring 2017 Cal Poly, Team S13-G4, Forte Spring 2017 회원
CPSU-FORTE-S17S13G4
4 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 6
전체 시간: 9
