소개
If you're unsure how to replace your Google Pixel XL display, follow the steps in this guide to replace your AMOLED display and digitizer assembly.
Replacement display adhesive will need to be used in order to secure your new screen.
If a shattered screen prevents the suction cup from obtaining an air-tight seal, covering the screen with packing tape may help the suction cup stick, and will also help secure glass shards and slivers. Additional heat and prying may be needed to separate the individual glass shards from the frame.
필요한 것
이 단계에 사용된 도구:Spudger$2.99
Put the flat end of a spudger under the lip of the press fit connector and lift up to pop the connector free.
Remove the LCD screen and digitizer.
To remove the unnecessary center section of the adhesive strip, carefully peel away the perforated rectangle in middle of the white backing. At the same time, peel up the black adhesive underneath the white backing.
