주요 콘텐츠로 건너뛰기
Google Pixelbook Display Replacement
필요한 것
  1. Google Pixelbook Display Replacement, Battery (Back Panel): 1 단계, 이미지 3개 중 1개 Google Pixelbook Display Replacement, Battery (Back Panel): 1 단계, 이미지 3개 중 2개 Google Pixelbook Display Replacement, Battery (Back Panel): 1 단계, 이미지 3개 중 3개
    • Use the iFixit opening tools or a metal spudger to pry the rubber covers off the back of your Pixelbook.
    • Peel the linings off completely until the back of the Pixelbook looks bare.
  2. Google Pixelbook Display Replacement: 2 단계, 이미지 2개 중 1개 Google Pixelbook Display Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the two yellow 2.0mm screws by using a T3 Torx screwdriver.
  3. Google Pixelbook Display Replacement: 3 단계, 이미지 3개 중 1개 Google Pixelbook Display Replacement: 3 단계, 이미지 3개 중 2개 Google Pixelbook Display Replacement: 3 단계, 이미지 3개 중 3개
    • Remove the seventeen 3.0mm T5 Torx screws from the bottom panel.
  4. Google Pixelbook Display Replacement: 4 단계, 이미지 3개 중 1개 Google Pixelbook Display Replacement: 4 단계, 이미지 3개 중 2개 Google Pixelbook Display Replacement: 4 단계, 이미지 3개 중 3개
    • Use the nylon spudger to pry the edge of the Pixelbook up until you can grab the edge with your fingers.
    • Open the back panel completely and lay it flat so you see the whole inside of the computer.
  5. Google Pixelbook Display Replacement: 5 단계, 이미지 2개 중 1개 Google Pixelbook Display Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the yellow 2.0mm screw from the middle of the panel by using the T3 Torx screwdriver to turn the screw counterclockwise.
  6. Google Pixelbook Display Replacement: 6 단계, 이미지 2개 중 1개 Google Pixelbook Display Replacement: 6 단계, 이미지 2개 중 2개
    • Remove the small, black casing by using the spudger to lift it up from its place.
  7. Google Pixelbook Display Replacement: 7 단계, 이미지 1개 중 1개
    • Disconnect the flat, black cord from the main component by using a spudger to push it out of the slot, or by using your hand to carefully pull it out.
    • Your back panel is now free from the main component.
  8. Google Pixelbook Display Replacement, Display Board: 8 단계, 이미지 1개 중 1개
    • Use an iSclack, or suction cup, to lift up the corner of the display from the case.
  9. Google Pixelbook Display Replacement: 9 단계, 이미지 3개 중 1개 Google Pixelbook Display Replacement: 9 단계, 이미지 3개 중 2개 Google Pixelbook Display Replacement: 9 단계, 이미지 3개 중 3개
    • Insert an opening pick into the gap between the display and case.
    • Repeat this procedure on other side.
  10. Google Pixelbook Display Replacement: 10 단계, 이미지 1개 중 1개
    • Using an opening pick, slowly pry up on the display until it separates.
    • Don't completely remove the display as ribbon cables connect it to the case.
  11. Google Pixelbook Display Replacement: 11 단계, 이미지 3개 중 1개 Google Pixelbook Display Replacement: 11 단계, 이미지 3개 중 2개 Google Pixelbook Display Replacement: 11 단계, 이미지 3개 중 3개
    • Use the pointed end of spudger to flip up the small locking flap on the ZIF connector.
    • Remove the display ribbon cable from the socket.
  12. Google Pixelbook Display Replacement: 12 단계, 이미지 3개 중 1개 Google Pixelbook Display Replacement: 12 단계, 이미지 3개 중 2개 Google Pixelbook Display Replacement: 12 단계, 이미지 3개 중 3개
    • Use the pointed end of a spudger to flip up the small locking flap on the ZIF connector.
  13. Google Pixelbook Display Replacement: 13 단계, 이미지 3개 중 1개 Google Pixelbook Display Replacement: 13 단계, 이미지 3개 중 2개 Google Pixelbook Display Replacement: 13 단계, 이미지 3개 중 3개
    • Flip the display over and lay it flat on the keyboard.
  14. Google Pixelbook Display Replacement: 14 단계, 이미지 3개 중 1개 Google Pixelbook Display Replacement: 14 단계, 이미지 3개 중 2개 Google Pixelbook Display Replacement: 14 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use a pair of tweezers to grab the clip on the display connector and swing it over to the other side of the socket.
    • Pull on the clip to disconnect the display.
    • Remove the display.
결론
다른 11명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Blake Klein
회원 가입일: 01/29/17
73,855 평판
안내서 50개를 작성함
9가이드 댓글
Where would you find a replacement display?
Carlos Garcia - 답글
Any idea on where to get a display replacement for the Pixelbook?
Nicolas - 답글
Is it necessary to remove the back in order to remove the screen? I cant see any connection between the two?
Thanks
Stevie B - 답글
You remove the back to disconnect the battery.
Sergio B -
any idea how to remove the glass shade on the back panel?
jon - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 27
지난 30일: 144
전체 시간: 12,648
