소개
In this guide, you will learn how to remove the motherboard of the Google Pixelbook in order to fix a faulty motherboard, ram, storage, and or processor.
필요한 것
Use the iFixit opening tools or a metal spudger to pry the rubber covers off the back of your Pixelbook.
Peel the linings off completely until the back of the Pixelbook looks bare.
Remove the two 3.0mm silver screws from the thin, black component by using a T3 Torx screwdriver to turn the screws counterclockwise.
Remove the three 2.0mm black screws from the sound card by using a T5 Torx screwdriver to turn them counterclockwise.
Remove the gold 3.0mm screw by using a T3 Torx screwdriver to turn it counterclockwise.
Disconnect the flat, black cord from the motherboard by using a spudger to push it upwards out of the slot, or by using your hand to carefully pull upward.
다른 9명이 해당 안내서를 완성하였습니다.
댓글 14개
You’ve put together a very good procedure for replacing a motherboard. My pixelbook needs a motherboard. Where can I buy one? Google does not sell them.
Tony Meier - 답글
Tony Meier - 답글
I believe the step8 & step16 mentioned “charging port“ shall be the loudspeaker in fact.
