주요 콘텐츠로 건너뛰기
Google Pixelbook Right Charging Port Replacement
필요한 것
  1. Google Pixelbook Right Charging Port Replacement, Battery (Back Panel): 1 단계, 이미지 1/3 Google Pixelbook Right Charging Port Replacement, Battery (Back Panel): 1 단계, 이미지 2/3 Google Pixelbook Right Charging Port Replacement, Battery (Back Panel): 1 단계, 이미지 3/3
    • Use the iFixit opening tools or a metal spudger to pry the rubber covers off the back of your Pixelbook.
    • Peel the linings off completely until the back of the Pixelbook looks bare.
  2. Google Pixelbook Right Charging Port Replacement: 2 단계, 이미지 1/2 Google Pixelbook Right Charging Port Replacement: 2 단계, 이미지 2/2
    • Remove the two yellow 2.0mm screws by using a T3 Torx screwdriver.
  3. Google Pixelbook Right Charging Port Replacement: 3 단계, 이미지 1/3 Google Pixelbook Right Charging Port Replacement: 3 단계, 이미지 2/3 Google Pixelbook Right Charging Port Replacement: 3 단계, 이미지 3/3
    • Remove the seventeen 3.0mm T5 Torx screws from the bottom panel.
  4. Google Pixelbook Right Charging Port Replacement: 4 단계, 이미지 1/3 Google Pixelbook Right Charging Port Replacement: 4 단계, 이미지 2/3 Google Pixelbook Right Charging Port Replacement: 4 단계, 이미지 3/3
    • Use the nylon spudger to pry the edge of the Pixelbook up until you can grab the edge with your fingers.
    • Open the back panel completely and lay it flat so you see the whole inside of the computer.
  5. Google Pixelbook Right Charging Port Replacement: 5 단계, 이미지 1/2 Google Pixelbook Right Charging Port Replacement: 5 단계, 이미지 2/2
    • Remove the yellow 2.0mm screw from the middle of the panel by using the T3 Torx screwdriver to turn the screw counterclockwise.
  6. Google Pixelbook Right Charging Port Replacement: 6 단계, 이미지 1/2 Google Pixelbook Right Charging Port Replacement: 6 단계, 이미지 2/2
    • Remove the small, black casing by using the spudger to lift it up from its place.
  7. Google Pixelbook Right Charging Port Replacement: 7 단계, 이미지 1/1
    • Disconnect the flat, black cord from the main component by using a spudger to push it out of the slot, or by using your hand to carefully pull it out.
    • Your back panel is now free from the main component.
  8. Google Pixelbook Right Charging Port Replacement, Right Charging Port: 8 단계, 이미지 1/2 Google Pixelbook Right Charging Port Replacement, Right Charging Port: 8 단계, 이미지 2/2
    • Remove the three 2.0mm black screws from the sound card by using a T5 Torx screwdriver to turn them counterclockwise.
    • Remove the gold 3.0mm screw by using a T3 Torx screwdriver to turn it counterclockwise.
  9. Google Pixelbook Right Charging Port Replacement: 9 단계, 이미지 1/1
    • Disconect the thin, black and red cord from the motherboard by using the spudger to snap the connector up and out of place.
  10. Google Pixelbook Right Charging Port Replacement: 10 단계, 이미지 1/1
    • Remove the yellow 2.0mm screw by using the T3 Torx screwdriver to turn the screw counterclockwise.
  11. Google Pixelbook Right Charging Port Replacement: 11 단계, 이미지 1/1
    • Remove the small, red component by lifting it up with the spudger.
  12. Google Pixelbook Right Charging Port Replacement: 12 단계, 이미지 1/1
    • Disconnect the metal component of the thin, black component by lifting it up with the spudger.
  13. Google Pixelbook Right Charging Port Replacement: 13 단계, 이미지 1/2 Google Pixelbook Right Charging Port Replacement: 13 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Remove the right charging port by picking it up with the tweezers and lifting it from the computer.
결론
Alon Gary
회원 가입일: 01/24/18
550 평판
안내서 2개 작성하였습니다
Cal Poly, Team S18-G1, Livingston Winter 2018 Cal Poly, Team S18-G1, Livingston Winter 2018 회원
CPSU-LIVINGSTON-W18S18G1
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 25
전체 시간: 1,604
