주요 콘텐츠로 건너뛰기
Gourmia GAF536 Screen Circuit Board Replacement
필요한 것
  1. Gourmia GAF536 Screen Circuit Board Replacement, Grey Top: 1 단계, 이미지 1개 중 1개
    • Use blue opening tool to pry open one side of grey top
    • If there is a loud pop, it is not broken.
  2. Gourmia GAF536 Screen Circuit Board Replacement: 2 단계, 이미지 1개 중 1개
    • Pry open all four sides.
  3. Gourmia GAF536 Screen Circuit Board Replacement: 3 단계, 이미지 1개 중 1개
    • Remove grey top.
  4. Gourmia GAF536 Screen Circuit Board Replacement, Screen Circuit Board: 4 단계, 이미지 1개 중 1개
    • Make sure hat that your air-fryer is turned-off and unplugged to prevent electrical shock.
    • Locate the internal tabs that hold the screen in place. (There should be 2 tabs on top, 2 tabs on the bottom, and 1 on each side.)
    • Focus on the side tabs.
  5. Gourmia GAF536 Screen Circuit Board Replacement: 5 단계, 이미지 3개 중 1개 Gourmia GAF536 Screen Circuit Board Replacement: 5 단계, 이미지 3개 중 2개 Gourmia GAF536 Screen Circuit Board Replacement: 5 단계, 이미지 3개 중 3개
    • Using your finger or the metal sludger, release the tab on the side.
    • Gently push the open side forward and place the blue opener into the gap from the front.
    • Repeat this on the other side.
  6. Gourmia GAF536 Screen Circuit Board Replacement: 6 단계, 이미지 2개 중 1개 Gourmia GAF536 Screen Circuit Board Replacement: 6 단계, 이미지 2개 중 2개
    • Once both sides of the screen have a blue opener, the screen can be safely popped out.
  7. Gourmia GAF536 Screen Circuit Board Replacement: 7 단계, 이미지 3개 중 1개 Gourmia GAF536 Screen Circuit Board Replacement: 7 단계, 이미지 3개 중 2개 Gourmia GAF536 Screen Circuit Board Replacement: 7 단계, 이미지 3개 중 3개
    • Remove the cable connecting the circuit board to the air-fryer’s motherboard by gently pinching the tab on the side connected to the screen.
  8. Gourmia GAF536 Screen Circuit Board Replacement: 8 단계, 이미지 2개 중 1개 Gourmia GAF536 Screen Circuit Board Replacement: 8 단계, 이미지 2개 중 2개
    • Remove all of the screws that attach the circuit board to the display screen and casing.
    • 7x PH 02 Screws: 5mm x 10 mm.
  9. Gourmia GAF536 Screen Circuit Board Replacement: 9 단계, 이미지 1개 중 1개
    • The circuit board can now be detached from the display screen, removed from the plastic casing, and replaced.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Hannah Fisher
회원 가입일: 09/08/23
324 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 20
지난 30일: 87
전체 시간: 1,707
