주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Governor Adjustment
필요한 것
  1. Governor Adjustment, Governor Adjustment: 1 단계, 이미지 3개 중 1개 Governor Adjustment, Governor Adjustment: 1 단계, 이미지 3개 중 2개 Governor Adjustment, Governor Adjustment: 1 단계, 이미지 3개 중 3개
    • Before starting, make sure the engine isn't running and is not hot.
    • Using needle-nose pliers, carefully unhook the spring from the end opposite the air filter.
  2. Governor Adjustment: 2 단계, 이미지 1개 중 1개
    • Use the needle-nose pliers to either lengthen or shorten the hook at the end of the spring.
    • If your engine is stalling or refusing to start, try shortening the spring. This will enable more fuel to reach to engine at idle. If the engine is bogged down when running and you hear liquids splashing, try lengthening the spring.
  3. Governor Adjustment: 3 단계, 이미지 1개 중 1개
    • Carefully re-hook the spring on the arm it was disconnected from.
결론
작성자
4다른 기여자 명과 함께
Aaron Correya
회원 가입일: 04/19/18
239 평판
안내서 2개를 작성함
Cal Poly, Team S25-G15, Maness Spring 2018 Cal Poly, Team S25-G15, Maness Spring 2018 회원
CPSU-MANESS-S18S25G15
4 회원들
안내서 7개를 작성함
2가이드 댓글
Wow, I'm very grateful.
Bradley Earnest - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 13
지난 30일: 84
전체 시간: 3,239
