주요 콘텐츠로 건너뛰기
Grace Digital Mondo Display Cover Replacement
필요한 것
  1. Grace Digital Mondo Display Cover Replacement, Front Panel: 1 단계, 이미지 1/1
    • Remove (2) screws (14 mm) with a PH1 screwdriver on the device.
    • There is one screw on the back left, and another just below it on the bottom of the device.
  2. Grace Digital Mondo Display Cover Replacement: 2 단계, 이미지 1/2 Grace Digital Mondo Display Cover Replacement: 2 단계, 이미지 2/2
    • Use a plastic spudger to remove the front preset selection buttons.
    • We recommend you remove all of them for easier access.
    • Gently reach underneath and pull off the mesh speaker cover. It only clips in so don't worry about breaking anything.
  3. Grace Digital Mondo Display Cover Replacement: 3 단계, 이미지 1/1
    • Remove (4) screws (14 mm) with a PH1 screwdriver on the front panel by the speaker.
    • Be careful with these screws, as they can be stripped easily.
  4. Grace Digital Mondo Display Cover Replacement: 4 단계, 이미지 1/1
    • Move the metal spudger around the front panel to remove any adhesive attaching the front panel to the device.
    • Pull apart the front panel from the device with help from the metal spudger.
  5. Grace Digital Mondo Display Cover Replacement: 5 단계, 이미지 1/3 Grace Digital Mondo Display Cover Replacement: 5 단계, 이미지 2/3 Grace Digital Mondo Display Cover Replacement: 5 단계, 이미지 3/3
    • Detach a pin connector at the top of the device using a metal spudger to open up the inner components.
    • Detach (4) pin connectors inside using a metal spudger to separate the front panel from the rest of the device.
  6. Grace Digital Mondo Display Cover Replacement, Display Cover: 6 단계, 이미지 1/1
    • Remove (10) screws (7 mm) with a PH1 screwdriver on the motherboard.
  7. Grace Digital Mondo Display Cover Replacement: 7 단계, 이미지 1/1
    • Separate the display and motherboard from the front panel of the device.
    • Remove the display glass.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Nathaniel Brabham
회원 가입일: 02/08/16
431 평판
안내서 3개 작성하였습니다
USF Tampa, Team 6-3, Eyestone Spring 2016 USF Tampa, Team 6-3, Eyestone Spring 2016 회원
USFT-EYESTONE-S16S6G3
4 회원들
안내서 8개 작성하였습니다
댓글 5개
Has anyone had to replace the digital volume control? Mine is intermittent. PCB solder joints all look good. I guess I will have to un-solder it to hopefully find a part number.
Richard Smith - 답글
Has anyone had to replace the rotary encoder volume control? Mine is intermittent. PCB solder joints all look good. I guess I will have to un-solder it to hopefully find a part number.
EDIT: No markings on it, but one on Ebay seems close enough to try. The shaft looks a little longer than the original. http://www.ebay.com/itm/2PCS-Rotary-enco...
Richard Smith - 답글
I’m experiencing the same issue with the volume control. Did you use this rotary encoder from Ebay and if so how did it work out?
Dan Gacek -
I used this procedure to install a phone jack that had more volume. It is hooked to the speaker with a switching jack. I just needed a little more volume. The above pictures made it possible to disassemble. I would have been lost without it.
Thanks
ironabby - 답글
Mine just stopped working (not turning on.) Wall plug/charger light lights up. Anyone else have this issue? Any solutions to fix it?
TS Project - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 6
전체 시간: 1,025
