주요 콘텐츠로 건너뛰기
Grace Digital Mondo Motherboard Replacement
필요한 것
  1. Grace Digital Mondo Motherboard Replacement, Front Panel: 1 단계, 이미지 1/1
    • Remove (2) screws (14 mm) with a PH1 screwdriver on the device.
    • There is one screw on the back left, and another just below it on the bottom of the device.
  2. Grace Digital Mondo Motherboard Replacement: 2 단계, 이미지 1/2 Grace Digital Mondo Motherboard Replacement: 2 단계, 이미지 2/2
    • Use a plastic spudger to remove the front preset selection buttons.
    • We recommend you remove all of them for easier access.
    • Gently reach underneath and pull off the mesh speaker cover. It only clips in so don't worry about breaking anything.
  3. Grace Digital Mondo Motherboard Replacement: 3 단계, 이미지 1/1
    • Remove (4) screws (14 mm) with a PH1 screwdriver on the front panel by the speaker.
    • Be careful with these screws, as they can be stripped easily.
  4. Grace Digital Mondo Motherboard Replacement: 4 단계, 이미지 1/1
    • Move the metal spudger around the front panel to remove any adhesive attaching the front panel to the device.
    • Pull apart the front panel from the device with help from the metal spudger.
  5. Grace Digital Mondo Motherboard Replacement: 5 단계, 이미지 1/3 Grace Digital Mondo Motherboard Replacement: 5 단계, 이미지 2/3 Grace Digital Mondo Motherboard Replacement: 5 단계, 이미지 3/3
    • Detach a pin connector at the top of the device using a metal spudger to open up the inner components.
    • Detach (4) pin connectors inside using a metal spudger to separate the front panel from the rest of the device.
  6. Grace Digital Mondo Motherboard Replacement, Motherboard: 6 단계, 이미지 1/1
    • Remove (10) screws (10 mm) with a PH1 screwdriver on the display board.
  7. Grace Digital Mondo Motherboard Replacement: 7 단계, 이미지 1/1
    • Remove the motherboard from the front panel.
    • If motherboard is difficult to separate, DO NOT force it. Check to see if all the screws were removed and proceed to remove the motherboard gently.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Nathaniel Brabham
회원 가입일: 02/08/16
431 평판
안내서 3개 작성하였습니다
USF Tampa, Team 6-3, Eyestone Spring 2016 USF Tampa, Team 6-3, Eyestone Spring 2016 회원
USFT-EYESTONE-S16S6G3
4 회원들
안내서 8개 작성하였습니다
댓글 한 개
Nice guide. My Mondo Wi-Fi went flaky (read “died”) so I disassembled using this guide to check out the wi-fi adapter plugged into the internal USB port. Turned out the little adhesive they apply to keep the adapter in the USB port sort of flowed over the adapter. Cleaned the adapter and plugged into the USB port on the rear of the radio and I’m back with a working Mondo. Glad iFixit does more than just computers and phones and pads (though it seems the Mondo is really a little Linux box).
csiemen - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 17
전체 시간: 3,565
