주요 콘텐츠로 건너뛰기
Graco Literider Classic Connect Seat Replacement
필요한 것
  1. Graco Literider Classic Connect Seat Replacement, Seat: 1 단계, 이미지 1/2 Graco Literider Classic Connect Seat Replacement, Seat: 1 단계, 이미지 2/2
    • Flip the stroller over so the back of the seat points upward.
    • Locate the twelve 12 mm Phillips screws holding the fabric to the frame of the stroller. Six are found along the back of the seat, and the other six are along the bottom of the seat.
  2. Graco Literider Classic Connect Seat Replacement: 2 단계, 이미지 1/2 Graco Literider Classic Connect Seat Replacement: 2 단계, 이미지 2/2
    • Using a Phillips #1 screwdriver, remove the twelve 12 mm screws and set them aside.
  3. Graco Literider Classic Connect Seat Replacement: 3 단계, 이미지 1/2 Graco Literider Classic Connect Seat Replacement: 3 단계, 이미지 2/2
    • Locate the two buttons holding the fabric basket frame on either side of the stroller.
    • Unbutton the two buttons.
  4. Graco Literider Classic Connect Seat Replacement: 4 단계, 이미지 1/2 Graco Literider Classic Connect Seat Replacement: 4 단계, 이미지 2/2
    • Locate the three velcro straps holding the seat to the canopy.
    • Undo the three straps.
  5. Graco Literider Classic Connect Seat Replacement: 5 단계, 이미지 1/1
    • Remove the seat from the frame.
    • When replacing the seat on the frame, some additional force may be required to insert the screws into their proper places.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Tyler Laird
회원 가입일: 09/29/15
540 평판
안내서 3개 작성하였습니다
Cal Poly, Team 11-4, Forte Fall 2015 Cal Poly, Team 11-4, Forte Fall 2015 회원
CPSU-FORTE-F15S11G4
5 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 11
전체 시간: 1,059
