주요 콘텐츠로 건너뛰기
Graco Paint Sprayers 17C325 2015 Gun Filter Replacement
필요한 것
  1. Graco Paint Sprayers 17C325 2015 Gun Filter Replacement, Remove the Handle: 1 단계, 이미지 1/3 Graco Paint Sprayers 17C325 2015 Gun Filter Replacement, Remove the Handle: 1 단계, 이미지 2/3 Graco Paint Sprayers 17C325 2015 Gun Filter Replacement, Remove the Handle: 1 단계, 이미지 3/3
    • Before you begin, make sure to follow the pressure relief procedure documented in the user manual before disconnecting and disassembling the spray gun.
    • Unscrew and remove the handle from the spray gun body.
    • You may need to use a pipe wrench to loosen the handle before removing it.
  2. Graco Paint Sprayers 17C325 2015 Gun Filter Replacement, Remove the Filter: 2 단계, 이미지 1/3 Graco Paint Sprayers 17C325 2015 Gun Filter Replacement, Remove the Filter: 2 단계, 이미지 2/3 Graco Paint Sprayers 17C325 2015 Gun Filter Replacement, Remove the Filter: 2 단계, 이미지 3/3
    • Use your fingers to remove the blue-tipped filter from the inside of the handle.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Craig Lloyd
회원 가입일: 02/10/16
35,617 평판
안내서 82개 작성하였습니다
댓글 3개
It would be beneficial to have the part numbers in this information as well! Otherwise, great job! Thanks
JANET - 답글
part number for the gun filter??????
BRITTINEY - 답글
288749 60 mesh gun filter
RICHARD -
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 13
30일 전: 49
전체 시간: 1,907
