소개
Follow this guide to disassemble and rebuild a leaky or clogged pump for the Graco Paint Sprayer, model 17C325.
Note: The pump’s rebuild kit comes with four black leather packing O-rings. Soak them in a cup of SAE 30 motor oil for an hour before installing them in the pump.
As you disassemble the pump, take the time to clean all the parts with soap, water, and a brush before reassembly, and replace any worn-out parts as needed, which are provided in the pump repair kit (part # 18B260).
필요한 것
Use your fingers to unscrew the jam nut securing the suction tube to the bottom of the pump.
Use your fingers to unscrew and loosen the connector securing the hose to the pump.
Once unscrewed, push the connector back to reveal the hose connection.
Use your fingers to unscrew and loosen the jam nut securing the pump to the paint sprayer.
Lift up the pump rod cover to reveal the pump's connection to the paint sprayer.
Pull the rear pump hose straight off of the pump.
Remove the pump from the paint sprayer.
Use a pick tool to remove the metal ball seat from the bottom of the intake valve.
Place the pump cylinder into a vise.
Use a flathead screwdriver and mallet to unscrew and loosen the top jam nut.
Use a pick tool to remove the black O-ring from the top jam nut.
With the pump cylinder still in the vise, use a mallet to gently tap down on the top of the piston rod to loosen it from the pump cylinder.
Remove the pump cylinder from the vise and pull the bottom of the piston rod completely out of the pump cylinder to remove it.
Use a pick tool to remove the black O-ring from the bottom of the pump cylinder.
Use a 3/4" wrench to remove the piston valve bolt from the piston rod.
Remove the piston valve bolt from the piston rod.
다른 19명이 해당 안내서를 완성하였습니다.
